Old 06-20-2005, 07:30 AM   #1
nerdling's Avatar
Default Battery Charging
Hi Guys,
So... what's the best way to charge my 3300mah and 3700mah batteries?
I'm currently using a Novak Melienium charger.
Current is 4amps
volt threahold is 13mv
I used to use Fan's but I've heard this is not necessary.
Also, I discharge the cells down to 5.4v and store them, is this OK? I've heard that folks discharge their cells, then charge them with about 1000mah, then when they next use them, they discharge them and charge them.
Thoughts??
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 06-20-2005, 07:39 AM   #2
Suspended
cr250 is offline   Reply With Quote
Old 06-20-2005, 06:08 PM   #3
dakrat's Avatar
most people i know charge their gp3300s at 6 amps. but if ur not comfortable with it, follow matcher's advice
dakrat is offline   Reply With Quote
Old 06-20-2005, 09:34 PM   #4
kavo's Avatar
what will happen if i over charge the battery(1700mah)?
kavo is offline   Reply With Quote
Old 06-20-2005, 09:35 PM   #5
kavo's Avatar
what will happen if i over charge the battery(1700mah)? I was charging the battery since last night 7pm (+8 GMT)
Old 06-21-2005, 12:02 AM   #6
PitCrew's Avatar
It depends on the charge rate. At .05 amps- probably nothing. You could probably chart at .05 continously for ages.
However at 5 amps, it should only take about 23 minutes to fully charge.
If you over charge the cells, you will first notice they get hot. THen you might hear a sizzling sounds. Then if your lucky you will notice something ooozing from the cells. If your not lucky, it will blow up, like KABOOM!!!!!
PitCrew is offline   Reply With Quote
Old 06-21-2005, 12:09 AM   #7
kavo's Avatar
Wow sound like trouble . But anyway I went home to off it already. Thanks hehe . By the way I am using the normal wall charger, do you know it's charge rate?
Old 06-21-2005, 10:52 AM   #8
dakrat's Avatar
probably less than 0.5 amps
Old 06-21-2005, 11:17 AM   #9
Superkidracer82's Avatar
Send a message via AIM to Superkidracer82
i charge mine at 6 to 6.5
Superkidracer82 is offline   Reply With Quote
Old 06-21-2005, 11:20 AM   #10
edseb's Avatar
I charge at 5.0amps for 19t or mod, and 7amps for stock. You'll lose run time at 7amps, but gain voltage. Do not charge with a fan on them. The fan will make it cooler and could make the batteries false peak. I also charge at 6 delta peak cut-off per cell, but that depends on the charger too. Also, it depends on what yourr batteries stared out at. I start out at .9 cut off discharge, but if it's an important Onroad race, I'll charge from a deadshort and watch the first couple of minutes in case of a false peak. Lastly, sometimes I'll peak by temperature, which is the best for the cells. I set it at 45c cut off.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 06-21-2005, 11:31 AM   #11
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I have changed the way I charge since the Much More Battery Heatsinks...
Now since the heatsinks spread the heat out over the intire pack I get a much lower temp so now that allows me to [email protected] 8Amps with the temp only getting to 45*C and that is the sweet temp for charging IMHO. I get much more punch and I have no problems with run time...But then again this is for 27 or 19T. But hey do what you like to your packs...But mine last just fine...
Oh yea I tray my packs over night on a discharge tray then right to the charger.
-Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Battery Charging rf096 Racing Forum 16 06-01-2015 03:24 PM
Charging Ni-Cd battery jayliu1984 Electric Off-Road 8 02-27-2008 11:32 AM
battery charging kracka Rookie Zone 1 11-23-2006 12:50 AM
Battery Charging t4mania Electric Off-Road 7 08-16-2006 09:41 PM
Battery charging? Maxxcrazy Electric Off-Road 1 05-11-2006 03:31 PM
