Old 06-20-2005, 03:51 AM   #1
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Default How to loosen a very tight grub screw??
G'day Guys,
I have a problem on my 415 where I need to remove 3 grub screws from the center shaft area so that I can replace spur gears but the grub screws are in there soooo tight that when I've tried to remove the grub screws, it either bends allen keys, breaks Hudy ProfiTool tips and bends Eagle Hex Driver tips.
Is there any solution anybody may have, perhaps with heat or something. I'm DESPERATE!!!!
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 06-20-2005, 04:07 AM   #2
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
have you taken the shaft out of the car and tried again with the allen keys?
dontfeelcold is offline   Reply With Quote
Old 06-20-2005, 04:21 AM   #3
Send a message via ICQ to elvo
1) drill out the bottom of the grub screw.
2) Pull the part off using a special puller
3) Hit the wrench with a hammer as you turn it.
elvo is offline   Reply With Quote
Old 06-20-2005, 04:28 AM   #4
F. Alonso's Avatar
Josh - Can't take the center shaft out of the car, I've taken the entire bulkheads out of the car.
Elvo.... I'm kinda reluctant to try that cause I don't want to damage the parts (as I have no spare gear holders, etc) and also the shaft has indents to hold the bits on, so unlikely to be able to pull it off without getting rid of the grub screw.
Really frustrating this.
Simon Feigl
Old 06-20-2005, 04:46 AM   #5
raving-monkey's Avatar
Send a message via MSN to raving-monkey
are you trying to use a 1.5mm allen key? if so then stick a old, worm 1/16 allen key in there and it will fit tighter...
another thing yu can try is, put boiling water onto it, this should loosen it...saying that, only do it if there isn't any plastic parts near that could melt
raving-monkey is offline   Reply With Quote
Old 06-20-2005, 04:51 AM   #6
F. Alonso's Avatar
Yes, been using 1.5mm hex driver. I do have some plastic around... but I'm gettin so frustrated with it all that I'd rather melt the plastic and get a new one from someone. We'l see what happens....
Any other suggestions??? I'm sure I'm not the only one who has had this problem.
Simon Feigl
Old 06-20-2005, 10:31 AM   #7
You might want to try using heat. If you have one of those small lighter torches, apply heat to the part that the screw is in. Although the grub screw will also get hot it might expand the part enough where it will allow you to remove the screw. No guarantees, but it might work. I have used heat to remove some stubborn screws/grub screws, sometimes it works sometimes it doesn't.
WailinOnYa is offline   Reply With Quote
Old 06-20-2005, 10:35 AM   #8
axel's Avatar
you can also either get a wet piece of towel or paper towel stick that in the grub screw than use your 1.5mm allen driver to turn it, this will try and fill in the spce you have.
axel is offline   Reply With Quote
Old 06-20-2005, 12:31 PM   #9
rtypec's Avatar
MIP/Thorpe Driver...if that don't get it out...you are pretty screwed
rtypec is offline   Reply With Quote
Old 06-20-2005, 12:36 PM   #10
NVisible's Avatar
Super Glue an old allen key in there?
Try the same with Solder?
NVisible is offline   Reply With Quote
Old 06-20-2005, 12:45 PM   #11
TeamMuchMore's Avatar
Try MIP Thorp Driver
if it strips with 1.5MM screw. there is inch size which is slightly bigger then 1.5mm use that to take it out. make sure you use the MIP thorp driver.
they are the best tool you can get for RC Hex screws
TeamMuchMore is offline   Reply With Quote
Old 06-20-2005, 01:42 PM   #12
pics?
MManson is offline   Reply With Quote
Old 06-20-2005, 01:50 PM   #13
sonneteer's Avatar
use 1/16th inch driver it works most of the time.
sonneteer is offline   Reply With Quote
Old 06-20-2005, 06:47 PM   #14
KoE
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
been there couple of times and yeah they sucked. super glue, solder, small torch just didn't do it. 1/16 inch driver might help in case of 1.5mm stripped screw. i had to tap the driver in lightly.
Originally Posted by F. Alonso
...I've taken the entire bulkheads out of the car(
dude, on the other side of the bulkhead, the shaft is held by an e-clip - remove that and you can slide the right bulkhead out leaving with the spacers assembly and the spur bound to the left b/head for you to work on. it gives you some clearance and lesser item to ruin. good luck!
Yo!
KoE is offline   Reply With Quote
My grub screw keeps popping out of my pinion whenever i drive bosley Electric On-Road 9 05-10-2008 02:31 PM
Pinch too TIGHT! rcfoolz Onroad Nitro Engine Zone 28 03-18-2008 05:41 AM
To tight of a pinch? pinky2252s Nitro Off-Road 3 11-25-2007 03:15 PM
tight xxx-s Electric On-Road 6 12-28-2006 12:40 AM
Help needed, i stripped the grub screw on my pinion.. MrRolla Australian Racing 17 05-28-2004 05:34 AM
