Old 06-15-2005, 01:21 PM   #1
GReddy's Avatar
Send a message via AIM to GReddy
Default 64 pitch gear meshing
hey if my gears are 64 pitch how should i mesh them? like say a normal peice of printer paper i just use a single peice and mesh them with that or is there a better way?
GReddy is offline   Reply With Quote
Old 06-15-2005, 01:24 PM   #2
edseb's Avatar
I just do it by feel. Mesh it so that it is tight, then back it off till you feel a slight play in the gears. With 64 pitch it will be very subtle compared to 48 pitch.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 06-15-2005, 01:25 PM   #3
Trader Rating: 18 (100%+)
I personally never liked the piece of paper theory but I have always tried to pull the pinion away from the spur about 1/3 the length of the tooth height. That has worked for both 48 and 64 pitch.
Chris Brown is offline   Reply With Quote
Old 06-15-2005, 01:30 PM   #4
axel's Avatar
I always insert the pinion. without tightening the grub screw, then I spin the spur to see how free it is, it should spin fairly well. It should also feels very free.
axel is offline   Reply With Quote
Old 06-15-2005, 01:55 PM   #5
ChadCapece's Avatar
Here's some money saving advice:
Since spur gears aren't true all the way around, the gear will not be a perfect circle. What you want to do is set the mesh to have a "tick" of play in the gears. Now spin the spur and pinion so that you can find the depressed side of the spur. Set the mesh to have a tick at that point. Then keep spinning it to make sure it isn't too tight on the other half of the gear.
This will save you money, b/c when most people blame their stripped spur b/c of tight or loose mesh, the mesh could have been right when you first looked at it, but the gear had a low side that was too loose. That low side will break the teeth and ruin the gear.
ChadCapece is offline   Reply With Quote
Old 06-15-2005, 11:52 PM   #6
GReddy's Avatar
k thanks
i ask this because i used the same electronics on my tt01 and the motor barely got hot
and now on my 414 the motor and esc gets really hot
Old 06-16-2005, 12:10 AM   #7
onnetz's Avatar
did you setup both cars to have the same rollout?
the mesh would have to be pretty tight to make the motor run hot.
onnetz is offline   Reply With Quote
Old 06-16-2005, 12:45 AM   #8
rough512's Avatar
When I'm installing a 64p 36T pinion, I'd install a 37t pinion and mesh the gears so it's snug. Tighten up the motor screws then remove the 37T and re-install the 36T pinion.
Perfect mesh. Works every time . I still do try to find the portion where the gear mesh is 'tightest' when installing the oversized pinion.
rough512 is offline   Reply With Quote
Old 06-16-2005, 12:51 AM   #9
Entropy's Avatar
The paper trick works in theory. However in the real world, no 2 papers are alike in GSM (thickness).
So dump the paper trick, unless you're meshing gas car gears.
For me I make sure i can rock the spur gear by feeling at the tightest mesh portion of the spur gear without visibly seeing the spur gear move.
Basically you can feel the play of the spur gear teeth and pinion but you shouldnt be able to see the spur gear move with your eyes.
Only ever stripped my spur gear twice. Once was when I forgot to tighten the motor on the mount, the other time was a crazy pebble got in between.
Entropy is offline   Reply With Quote
Old 06-16-2005, 01:08 AM   #10
jland's Avatar
Trader Rating: 74 (100%+)
Here is a trick I learned that seems to work well on 64P. If you want to run a 24T pinion, put a 25T on and push the motor up to the spur, take it off and put the 24T on. Perfect mesh every time.
jland is offline   Reply With Quote
Old 06-16-2005, 01:45 AM   #11
edseb's Avatar
Ooh, I like the idea of that technique; got to try that one.
Carl Hyndman
Old 06-16-2005, 07:48 PM   #12
GReddy's Avatar
it might be that its a 8:1 ratio not sure about the roll out so its probably because i had to hold the throttle all the way a hole lot more
Old 06-16-2005, 08:06 PM   #13
Jeff Brown's Avatar
Well, if the drivetrain ratios are different then you will need a different pinion. Other than that you should be fine.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
64 pitch gear set SteveJa R/C Items: For Sale/Trade 5 02-03-2008 09:55 AM
FS: 48 Pitch Gear set ewippler R/C Items: For Sale/Trade 5 10-16-2007 10:14 AM
A question about gear meshing bxpitbull Electric On-Road 8 09-19-2007 07:46 AM
Gear pitch tractorpull Rookie Zone 4 02-19-2006 02:28 PM
48 pitch gear set dmayhew25 R/C Items: For Sale/Trade 1 11-08-2005 11:38 AM
