Old 06-14-2005, 08:05 PM   #16
HarshGuy's Avatar
I don't know anything about mechanical design, stress areas, etc... but I do know that looks hella kewl ...if you've ever had to screw on a shock end on an xray shaft ...you'd know what I mean a hex on the opposite end like that would be so kewl
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 06-14-2005, 08:29 PM   #17
Send a message via AIM to adootindotin
that's a good idea, i'll bet P dub offers one in less than a month
adootindotin is offline   Reply With Quote
Old 06-14-2005, 08:33 PM   #18
P-DUB's Avatar
Is that a request...
Larry Pryor
P-DUB is offline   Reply With Quote
Old 06-14-2005, 09:11 PM   #19
scoobydo's Avatar
Absolutley!!
"P Dub in association with Scoobydo Ideas Presents...."
scoobydo is offline   Reply With Quote
Old 06-14-2005, 10:13 PM   #20
VenomWorldOrder's Avatar
that is the best, most simplest and best "updated design of a old design" idea i have ever seen!!
that would eliminate all the pliers on the shaft problems. honestly, that would not cost much more to make than it costs to make a screw. seriously. there is nothing difficult in it and all the kudos to gain.
VenomWorldOrder is offline   Reply With Quote
Old 06-14-2005, 10:27 PM   #21
R/C Tech Founder
R/C Tech Charter Subscriber
Originally Posted by Jon Kerr
No, I think what Losi did was tap the end of the shaft so the pistons are held on by a button head screw instead of E-clips. But you can put the screw in and use it to thread in the ball end on the shaft like scooby's idea. Both are good ideas though.
I actually thought this was the single coolest and most innovative feature of the JRX-S. I built an Xray the day before I built the Losi, and after wringing my wrists trying to get those shock ends on, the Losi was like a breath of fresh air.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 06-14-2005, 11:45 PM   #22
danjoy25's Avatar
Trader Rating: 37 (100%+)
Mugen shocks uses 3mm nuts which I think is better.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 06-15-2005, 12:53 PM   #23
scoobydo's Avatar
We talked about stress points earlier.
Wouldn't putting a thread on top of the shaft for a button screw be even more stress than just a hex hole?
OR
Does the addition of the button head screw add the stability back to the weakened shock shaft?
Also how is the security of the screw? Being as how shocks take the most action on a run, would you need thread lock?
Anybody got pics of the new Losi Shock Shaft?
Old 06-15-2005, 01:00 PM   #24
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I don't know if Losi says to thread lock them but I would.
Jon Kerr is offline   Reply With Quote
Old 06-15-2005, 01:35 PM   #25
rc-car-net's Avatar
Send a message via ICQ to rc-car-net Send a message via MSN to rc-car-net
Exclamation
great idea! and i'm very interessted to try such shocks
scoobydo, please keep me informed if you would try to build something like that.
just email me or send me a pm
[SIZE="1"][URL="http://www.Rc-Car-Net.at"][COLOR=RoyalBlue]Rc-Car-Net[/COLOR][/URL] [COLOR=Cyan]-=-[/COLOR] [URL=http://www.RC-FORUM.at][COLOR=RoyalBlue]RC-Forum.at[/COLOR][/URL] [COLOR=Cyan]-=- [/COLOR] [URL=http://www.racing-cars.com][COLOR=RoyalBlue]Schumacher USA[/COLOR][/URL] [COLOR=Cyan]-=- [/COLOR] [URL=http://www.fantomracing.com][COLOR=RoyalBlue]Fantom Racing[/COLOR][/URL]
:tire::sneaky:[/size][size="2"] ................................. :sneaky::tire:
:sneaky::tire:[URL=http://www.summerchamps.de][COLOR="DarkOrange"]GERMANY Summer Champs[/COLOR][/URL][/SIZE]:tire::sneaky:
:tire::sneaky: ................................. :sneaky::tire:
rc-car-net is offline   Reply With Quote
Old 06-15-2005, 01:45 PM   #26
TRF415boy's Avatar
I have a solution for X-Ray owners : get decent shocks Never had an issue with that running tamiya shocks and i tell you right away, it's a nice idea, only thing is it's impossible to make for different reasons, one of which being the fact that if you make a hex print at the end of the shaft and you use e-clips to keep the piston in place, you either end up with shafts with a lot of material at the end after the piston or with a very weak shock shaft. Also, for those who don't know, there is no such thing as a precision screw.
TRF415boy is offline   Reply With Quote
Old 06-15-2005, 01:45 PM   #27
PitCrew's Avatar
I think this is a great idea.
However, as has been mentioned, the extra cost of machining may be prohibitive. If the hex is indeed machined in the end, it would have to be "Shaped". This means that a very small, probably square or triangular cutter is punched up and down as the tool and work-peice rotate in a manner to correctly form the hex. THis is how internal gears are made when they are not all the way through. (that type of operation is usually broached, unless a very close tolerance and great finish are required). I am a journey level machinist, with over 800 hours in gear machining....
the main dificulty lies in the mere size of the work peice and tooling required to do this.
I am thinking an external hex, just larger than the shaft OD would work. The shoulder of the hex could be used to hold the pistion on one side as well, so you would only need the one e-clip on the other side. Then you could use pliars or better yet, a nut driver to firmly hold the shaft. It would also help reduce any problems with stripping.
PitCrew is offline   Reply With Quote
Old 06-15-2005, 03:16 PM   #28
I used to use my dremel to grind a slot in the end of the shock shaft, lot like the hex in the drawing, (only slot, not a hex ). But the dremeling has to be very accurate and some shafts hardly give you any material to work with so the slot ends up very shallow.
andsetinn is offline   Reply With Quote
Old 06-15-2005, 09:10 PM   #29
scoobydo's Avatar
Yeah, i thought of that too. But like you said, it would leave the shafts pretty weak up top and you risk damaging the pistons when you put then in or out.
I don't see machining costs being that much of an issue.
If they were offered as option parts, you could charge more to compensate.
Right now I pay $9.00 for 2 xray shafts.
I would be willing to pay anywhere from $13-18 a pair for the convenience of the hex screw.
Old 06-15-2005, 10:19 PM   #30
You guys might check out our locking shock shaft pliers at www.teamtamale.com on the RC Car Tools page. These hold the shock shaft of just about any shock securely without fear of damaging the shaft.
teamtamale is offline   Reply With Quote
FS: LST shock with hard coated body and Ti-Ni shock shaft yahhoo R/C Items: For Sale/Trade 6 03-27-2008 01:04 PM
shock shaft pliers? gonzo416 Electric On-Road 24 11-02-2006 05:27 PM
Shock shaft info andrewdoherty Electric On-Road 1 07-12-2006 06:47 AM
Hellfire Shock Shaft Wear mxermadman Electric Off-Road 2 04-04-2006 11:02 AM
Shock shaft assembly tool forty6 Electric On-Road 2 09-26-2004 01:10 PM
