Old 06-14-2005, 12:46 PM   #1
Default Spectrum question
I am thingking about buying an spectrum set but i have heard some problems about it and i would like to know more about that.
I heard that the spectrum had problems with KO Propo 2343 servo's?
the Combination will be: Sanwa super Exces spectrum and ko 2343.
Does someone know more about this combination?
Thanks.
Arjen
Arjen is offline   Reply With Quote
Old 06-14-2005, 02:30 PM   #2
I would also like to know if the spectrum unit for the sanwa M8 will work in the sanwa super exzes.
It's almoast the same transmitter but the one is stick and the other steering wheel.
thanks,
Arjen
Old 06-14-2005, 02:37 PM   #3
rocketron's Avatar
Trader Rating: 16 (100%+)
i think you best ask the spektrum folks directly on this one -
http://www.spektrumrc.com
rocketron is offline   Reply With Quote
Old 06-14-2005, 03:01 PM   #4
Super Moderator
Grizzbob's Avatar
Right, it's hard to say, though I do think that the ESC you have is actually the biggest factor in how well it'll work out(seems some ESC's have a BEC that can't quite supply enough amps to run the Spektrum & a strong servo, but others do, like my Novak GT7, it's never had a problem)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-14-2005, 08:19 PM   #5
schmelme's Avatar
I am running a pair of 2343's in my 1/8 scale and performs flawless hopes this helps.
schmelme is offline   Reply With Quote
Old 06-15-2005, 02:16 AM   #6
17driver's Avatar
R/C Tech Charter Subscriber
If you were to have a problem all you need to do is run a resistor cap.Spektrum is going to be releasing a resistor cap at the end of June.
Midwest malitia member
17driver is offline   Reply With Quote
Old 06-15-2005, 03:01 AM   #7
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I have a 2133 with a Spektrum and a GT-7 and it works fine. I think the 2133 is very similar to the 2343 specs only with plastic gears.
Just got mine last week...it totally kicks "A". I love it.
Turbo Joe is offline   Reply With Quote
Old 06-15-2005, 11:36 AM   #8
jonest's Avatar
I needed a capacitor to run spectrum on Quantum 2 and KO's 2343.
It seems that the Q2 have problem on supplying the voltage.
hope this helps.
jonest is offline   Reply With Quote
Old 06-22-2005, 10:58 AM   #9
A couple of days ago i recieved my Spectrum kit.
The kit is an Airtronics version and works in the super exzes.
But not with the KO2343 servo.
Does someone already know how to solve this?
Somebody told me spectrum will release an capacitor to solve the problem does someone know more about this?
Thanks for the help
Arjen
Old 06-22-2005, 11:14 AM   #10
TeamPink91's Avatar
Send a message via AIM to TeamPink91
I know Spektrum is going to be releasing their own power capicitor, but you can just go to radio shack and get one and attach it to a receiver plug.
TeamPink91 is offline   Reply With Quote
Old 06-22-2005, 11:46 AM   #11
Thanks for your reply.
And do you know what kind of specs the capacitor has to have?
so i can look for the right one.
Thanks,
Arjen
Old 06-22-2005, 12:57 PM   #12
TeamPink91's Avatar
I'm using a capacitor that has 2400 uf and 10 volts because it's the only thing I could find at my radio shack that is close enough to doing the job, but most people use a 4700 uf capacitor rated for 6-10 volts.
Old 06-23-2005, 09:16 AM   #13
Thanks for your help.
And i can mount that capacitor just like an personal transponder by just putting it in a slot?
Arjen
Old 06-23-2005, 09:37 AM   #14
TeamPink91's Avatar
Yep, you just have to make sure you attach the negative wire to the negative lead on the capacitor and positive to positive so it functions. I just used a receiver plug from an old servo I had laying around, but you can use something like this to solder onto the capacitor.
http://www2.towerhobbies.com/cgi-bin...?&I=LX0896&P=0
Old 06-24-2005, 08:13 AM   #15
But i have an other question.
now you use an channel for the capacitor and how do you use your AMB Personal Transponder then?
Spectrum question M11 N2Otorious Radio and Electronics 4 07-02-2008 10:53 PM
WTB:Spectrum DX2.0 Snipesr82 R/C Items: Wanted to Buy 6 06-16-2008 04:23 PM
WTB 3PK with spectrum Jason Halvorson R/C Items: Wanted to Buy 0 10-07-2007 10:25 PM
JR Spectrum DX 3.0 Lennydude Electric On-Road 0 10-06-2007 10:59 AM
AIRTRONICS M11 W/SPECTRUM AND 2 SPECTRUM RECEIVERS burm R/C Items: For Sale/Trade 10 03-05-2006 01:28 PM
