Old 08-12-2013, 01:42 PM   #1
Default to charge without balance board on icharger 3010b
Hello,
I received my icharger 3010b without balance board, and my hyperion board don't fit on it... so why not to delete it of the pit table.
I try balance wires like this but it don't work... I have to got +/- at the extremity of the plug. ( reverse polarity error )
I will only use 2 S lipo
Manson is offline   Reply With Quote
Old 08-12-2013, 02:51 PM   #2
Skiddins's Avatar
Always balance charge.
If you don't, at best you'll lose performance, at worst you will cause a fire.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-12-2013, 03:05 PM   #3
Reverse polarity ususally means your leads are pluged in back wards .. make sure all leads are correct and your charger is set up on balance charge .. if your charging in lipo charge mode with the balance lead pluged in youll get an error . if charging without balancing make sure the plug is disconnected .or youll get en error ...check your batteries. some manuf positive and negitive leads are opposit of eachother ..
Mark Barden .
mb racer is offline   Reply With Quote
Old 08-12-2013, 04:45 PM   #4
The question wasn't about to balance or not the lipo.
I m looking to get the right cable to charge my lipo ( and balance ) without a board.
Old 08-12-2013, 05:47 PM   #5
If everything you,ve connected is correct . and your getting an error . Id call and chk with manuf of the charger ..
Mark Barden .
Old 08-13-2013, 02:19 AM   #6
Skiddins's Avatar
Sorry, misunderstood.
Sounds like the connector you have is wired up differently from the correct balance lead for that charger.
You need to either get the correct balance lead for that charger, or take the wires out of the balance lead's white connector and wire them up so they are correct (If the actual connector is the same)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-13-2013, 06:50 AM   #7
Strange, i got only "reverse polarity" when no lipo is connected. My balance cable seems to work.
No reverse polarity on the screen when all is unplug from the charger
