Old 08-10-2013, 09:27 AM   #1
dewxone's Avatar
Default what combo to use for 1/10 speed runs?
Hi guys.. I have a speed run project..with my TA Tc4.. I'm looking gor a brushless setup for 3 s lipo.. maybe u can help..I've been running a Toro Leopard 13t combo. (Super cheap combo $60).and had some sick speed on it..but I'm pretty sure..I can do better..
Maybe anyone cn help me out on this one
dewxone is offline   Reply With Quote
Old 08-10-2013, 12:10 PM   #2
ThePanda's Avatar
Trader Rating: 65 (100%+)
One of the castle sidewinder system combos would work great I think.
ThePanda is offline   Reply With Quote
Old 08-12-2013, 01:08 AM   #3
Suspended
Default how aboust tenshock and hobbywing's combo
tenshock's motor is suit for you.
more details:http://www.funshobby.com/index.php/gallery-37.html
MOTONICA 1/10,1/8 ON ROAD TIRE IN STOCK
TENSHOCK X501 1:5 8 POLE MOTOR
http://www.aliexpress.com/fm-store/105454
FUNSHOBBY1 is offline   Reply With Quote
Old 08-12-2013, 02:05 AM   #4
SWTour's Avatar
Contact John @ BSR Tires - he made speed run CAPPED tires a few years ago that worked really well - unless you are trying to top 200 mph - then you'd want someone to build you TALLER wheels - maybe carbon fiber, and run FOAM that isn't too thick - so it doesn't BLOW off the wheel.
It's hard to keep tires on the cars over 120+ mph (and most regular TC tires - don't make it past 70 or so)
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 08-18-2013, 08:27 AM   #5
dewxone's Avatar
Thanx!! Should I go with higher or lower kv? Will this hold at least 4s lipos?
Old 08-18-2013, 08:47 AM   #6
dewxone's Avatar
Originally Posted by SWTour View Post
Contact John @ BSR Tires - he made speed run CAPPED tires a fe. years ago that worked really well - unless you are100mphying to top 200 mph - then you'd want someone to build you TALLER wheels - maybe carbon fiber, and run FOAM that isn't too thick - so it doesn't BLOW off the wheel.
I actually was trying to go at least 100mph...I got a pretty stock tc4. . Got me a 120a 9100kv Hobbywing combo.. but I'm guessing I can't put a 4s lipo.. so I will have to do only.. 3s.. sooo.. i have a 60t spur with 45t pinion.. and some cheap foam tires..
Just order a 52t spur gear.. and 48t pinion gear..
Not quite sure what I'm gonna get out of it.. but hope it is good. got a match with a 1/8 gt with mamba monster 2200kv.. lol..his doing 100mph.. with 6s..
I might have to need a mamba max esc..to use 4-6s lipos! That's were the real speed is..
Old 08-18-2013, 10:54 AM   #7
ThePanda's Avatar
Yeah a mmp is rated up to 4,6s, but make sure the motor is also, most 540-550 cans are only rated for 2-3s max
Old 08-18-2013, 12:45 PM   #8
SWTour's Avatar
If you plan to use a high KV motor and multi-cells, just remember HIGH RPMS blow the tires off really quick - and it's really easy to over gear and burn your electronics to the ground.
Get a good balance on your aero/downforce. Just a tiny spoiler on the rear wil pull your front wheels off the ground at high speed really quickly.
Joe Myers
Old 08-19-2013, 05:40 AM   #9
I also want a 3s combo for my touring car to run in nitro tracks with same speed of nitro models, but I don't know what to buy.
There is no much choice in this class, do you know something good for my target ?
maRRRco is offline   Reply With Quote
Old 08-19-2013, 09:58 PM   #10
FLoJo's Avatar
I ran a vxl system for couple runs on my FT TC4 and it was a beast on 3s . LHS guy sold me some nitro shoes foams for hi speed running
KYoSHo iNFeRNo GT1-E RCMoNSTeR CaSTLe2200 <> KYoSHo iNFeRNo GT2Ve Tekin 2650
oFNa LM DO CaRBoNFiBeR CaSTLe2650 <> TC4 FT
ZDRaCiNG TRuGGy <> HPI NiTRo RS4 .21oS
PRoBoaT STiLeTTo <>TRaXXaS SPaRTaN
FLoJo is offline   Reply With Quote
Old 09-01-2013, 11:26 PM   #11
dewxone's Avatar
Are you looking for something cheap? Or you wanna race?
Hobbywing.. Castle or Novak.. the kv depends on your track condition.. you really wanna gear right. for touring i would go for higher kv.. 5k or more..
Old 11-14-2013, 12:06 AM   #12
Suspended
Default which one do you want 401v2 or 411?
what combo to use for 1/10  speed runs?-sc-401-v2-2.png   what combo to use for 1/10  speed runs?-411-.jpg
Old 11-14-2013, 01:12 AM   #13
alloyslash's Avatar
Trader Rating: 19 (100%+)
Youtube search " 100mph rustler in traffic ". That guy runs 1/8 scale Castle power on 6s. Watch related videos, he "hints" about different things its took to go that fast without distructing. Foams are a must, all metal gears, lots of weight on nose, etc.
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 11-20-2013, 10:57 PM   #14
Suspended
Tenshock +howbbywing is very good
haha is offline   Reply With Quote
Old 11-25-2013, 01:29 AM   #15
i think so
Shop Address:
You can always email your questions to below:
[email protected]
hobby jolly is offline   Reply With Quote
