Like Tree2Likes
Tamiya TRF418
Old 07-22-2014, 08:28 PM
  #1411
Originally Posted by cplus
Has been that way for a while.
Seems to be the way with TRF kits, Tamiya tool up and smash out one or two runs and that's it. Then the update comes in the case of the popular kits.
Did your kit come with extra/spare parts? Spings, sways, plastics?
It did come with the bonus parts.
Pic shows all three spacers installed. I have about couple tenths of a mm to spare.
I first put the suspension blocks together loosely. Then I press back on both arms (towards the center of car) and tighten the inner blocks. I then do the same thing for the outer block but applying outward pressure to the arms. That's how I did it. Maybe I just got lucky...
inpuressa is offline
Old 07-22-2014, 09:26 PM
  #1412
Spare parts means it is unlikely to be from a different batch to the rest of us. Dunno.
But if you can fit all the spacers/shims per kit, without shaving/sanding/trimming the arms, and they still move freely - then that's excellent
cplus is offline
Old 07-22-2014, 09:28 PM
  #1413
Originally Posted by Dan
Haha, this is what happens when we get anal about slop. Will never see me with an Associated touring car.
Are associated particularly bad? I've never owned/seen one up close enough.
cplus is offline
Old 07-22-2014, 10:02 PM
  #1414
Simmi's Avatar
@cplus
I do not know it differently from Tamiya kits, never had problems with freely moving arms.
You could also 0.7mm shims take instead of 1mm shim to get freely arms.
Simmi is offline
Old 07-24-2014, 07:29 PM
  #1415
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Anybody know exactly how long the shocks are supposed to be for the 418. There is nowhere that says the information for suggested total length. I have all four of mine at 61.50. Seems ok. Just making sure
xrayaustin is offline
Old 07-24-2014, 07:39 PM
  #1416
JimmyMac's Avatar
61.5mm is standard for Tamiya shocks. 57.75mm for short shocks.
JimmyMac is offline
Old 07-25-2014, 12:09 AM
  #1417
acutts's Avatar
Just bought a TRF418 after being out of the hobby for 5 years. My local track requires a final ratio of 3.15 (Using a 17.5t brushless and Fleta euro blink esc)
Is it possible to run a spur an pinion to give this in 64 or 48dp? If so any ideas what I will need to get. Just started building it and worried about ordering something that will not fit.
Any help greatly appreciated.
acutts is offline
Old 07-25-2014, 12:22 AM
  #1418
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
NB: My bad - in my original post I used the 417's internal ratio of 1.947. The 418 has an internal ratio of 1.85. Correct values below. Sorry.
You can use any gear ratio calculator, from gearchart.com to a spreadsheet, to help work out what you need. In 48P, a 63 spur and 37 pinion will get you very close.
I'm guessing it's quite a large, flowing track?
PDR is offline
Old 07-25-2014, 01:06 AM
  #1419
The TRF418 has an internal ratio of 1.85
So you can just look for a combo to fit that
Zen racing has a large amount of the Panaracer spurs that fit. I would get somehing like an 88t (64dp) and a 52t pinion (64dp)
Qatmix is offline
Old 07-25-2014, 01:09 AM
  #1420
JimmyMac's Avatar
A 92 spur and 54 pinion will land you right at 3.15.
JimmyMac is offline
Old 07-25-2014, 01:45 AM
  #1421
acutts's Avatar
Thanks will those fit under the deck etc?
acutts is offline
Old 07-25-2014, 01:47 AM
  #1422
acutts's Avatar
Cheers so no probe fitting such a big pinion under the deck?
acutts is offline
Old 07-25-2014, 02:11 AM
  #1423
Not that I can envisage, I have used a 50t the pinion is in the middle and pops out between the two prongs of the upper deck.
Where are you racing?
Qatmix is offline
Old 07-25-2014, 02:25 AM
  #1424
acutts's Avatar
Aldershott in the UK
acutts is offline
Old 07-25-2014, 02:50 AM
  #1425
JimmyMac's Avatar
Yes, I'm running 96/54 with no problems and I can go a little bigger pinion if needed.
JimmyMac is offline
