Like Tree2Likes
Tamiya TRF418
Old 06-19-2014, 01:24 PM
  #1231
Has anyone else experienced HPI Silver springs with barely any silver paint marking them? I have 3 pairs of them and only one pair has any noticeable silver paint on them. This gets aggravating when you consider the Tamiya 418 kit springs as identical as well as the Ride Black springs. Thankfully the Ride Silver springs use 1.4mm wire so they're easy to identify but all the others seem to be 1.5mm!
c2tcardin is offline
Old 06-19-2014, 01:59 PM
  #1232
Trader Rating: 32 (100%+)
Worse. I've purchased two sets in the last few months with no paint at all.
ittjv is offline
Old 06-19-2014, 03:01 PM
  #1233
masterhit's Avatar
Trader Rating: 16 (100%+)
Ride and Tamiya springs are wound opposite of HPI springs. An easy peazy tell.
Mike Slaughter
masterhit is online now
Old 06-19-2014, 03:57 PM
  #1234
What is the reason to run without rebound? Like JG puts holes in his shocks or Rod not using sponges at Reedy?
LAGuy is offline
Old 06-19-2014, 04:08 PM
  #1235
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
I believe the idea is that, a damper is not a spring, pretty rare to see anyone use the sponges
RedBullFiXX is offline
Old 06-19-2014, 08:42 PM
  #1236
Dusttt's Avatar
Trader Rating: 144 (100%+)
Is there a 418x coming out soon? The $430 418 at Tower seems too good to pass up.
Dusttt is offline
Old 06-19-2014, 10:16 PM
  #1237
2-Bad's Avatar
Trader Rating: 24 (100%+)
There is an echo in here, haha
2-Bad is offline
Old 06-19-2014, 10:47 PM
  #1238
Dusttt's Avatar
Post was really meant to be about the price more than anything.
Dusttt is offline
Old 06-19-2014, 11:18 PM
  #1239
What discounts is that with?
Do you have to pay a fee to get access to the discount?
cplus is offline
Old 06-20-2014, 06:35 AM
  #1240
Dusttt's Avatar
Just the tower saver club it's $10 a year. They have the car at$504 and there is a $75 off $500 code
Dusttt is offline
Old 06-20-2014, 09:37 AM
  #1241
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Mike Slaughter
You sure? Pretty sure Tamiya springs are wound the same way as HPI.
HPI blue - straight out of the package:
Tamiya blue -
And, if someone would be so kind, what the heck is this one? Wound opposite, 13.59mm ID, 15.49 OD, 5 coils, 1.4mm wire.
CraigMBA is offline
Old 06-20-2014, 09:59 AM
  #1242
masterhit's Avatar
I was referring to the new large diameter "black" Tamiya springs.
The Tamiya black is pretty unique compared to the other coatings. It looks like a trivalent zinc chromate, hence the lack of color density and the heavy "rainbow" affect. That alone is usually enough for me to tell!
The bottom mystery spring is wound in the direction of the new Tamiya springs. All the new Tamiya springs use 1.5mm wire (per Tamiya) and vary the coil count to change the rate. Mine check out to confirm this. The most likely candidate is a Ride spring.
Mike Slaughter
Old 06-20-2014, 11:04 AM
  #1243
CraigMBA's Avatar
Mike Slaughter
I see how we got that one confused!
CraigMBA is offline
Old 06-20-2014, 11:49 AM
  #1244
For me, I found it easier to make 4 dead dampers from the beginning than trying to make them all equal. Even if I did, they lose compression at different rates. Consistency is the keyword here I guess.
inpuressa is offline
Old 06-20-2014, 11:50 AM
  #1245
