Tamiya TRF418
#872
I also have a front gear diff to try with 1m and 1K rear diff as well.
#875
Yeah sorry here it is. I was actually having a bit of a problem with over steer so I took the sway bar off. Also planning on going back to the 3rd hole in the rear shock tower. Any other input would be great. Track is medium traction parking lot.
Hope this helps.
#876
Well I have HPI blues in my box so I might give those a try. what do you think about the above mentioned on going to harder springs? (Not trying to start a argument)
And as minami said more camber? Half degree to much?
#877
6 & 5 droop is not enough droop. Your car is running too flat and stopping the suspension from getting any mechanical grip, hence graining the outside edge of the tyre. 5 & 4 would be what I would suggest to start with.
I agreed 3k is too heavy and 1k would be better for outdoor asphalt carpark track.
Then if still not enough grip, go to a softer spring.
You never showed your camber setting on your sheet so start with 1.5 deg Frt, and 2 deg Rr.
Your shock oil, shock angle, and the rest all seems fine.
As you have put up your setup sheet, ppl now can offer advice (advice is free, lol). It's up to you now to determine which advice best suits your conditions as we here can only estimate those (one persons medium grip carpark is another's low grip permanent track).
Good Luck!
#878
Hi Nick
Look for your Suspension arms if they works free and turn down the ground clearance to 5 all or 5 front back 5,2. 5,5 is to high.
And how 2-Bad write look at your camber 1,5 front 2 back. You'll notice a difference.
The rest looks pretty good.
#879
I would suggest in order of the following;
Good Luck!
Good Luck!
I am at 1.5 and 2 on camber. I thought I added that in there.
Thank you for your input I will give this all a try!
#880
And im at 1.5f and 2r on the camber. Must have missed it on the sheet. are you saying to go to 2 front and rear?
And all my suspension is free moving.
#881
I wouldn't run lower than 6 unless it was a permanent track like Tamiya, Jackson, Full Throttle, etc. Try running 800 in the rear diff before making too many changes. 3k was way too high for a med grip parking lot. I would stay with 32.5 and HPI silvers in the shocks though.
#883
#884
Basically, run what ride height prevents the car from dragging the edges hard enough to have an effect on the handling of the car. My particular parking lot track requires me to run 6mm. If I go lower it will begin to drag in high-speed and high brake areas. As far as a parking lot is considered, it's medium, but on the smooth side.
