Like Tree2Likes
Tamiya TRF418
Old 04-07-2014, 01:15 AM
  #856
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by niznai
That sounds strange or missed something. Less caster=more steering, right?
Less caster = more low speed steering (yes), less high speed steering
More caster = less low speed steering, more high speed steering
2-Bad is offline
Old 04-08-2014, 11:53 AM
  #857
I'm curious, does anyone shim their front hub assemblies where they connect to the lower arms to take out some of the play?
c2tcardin is offline
Old 04-08-2014, 12:36 PM
  #858
b20btec's Avatar
I do, I shim accordingly. I also shim the barrel washers connected to the upper links. It doesn't take much to get it right but you will notice a difference when you check your droop, the play will be gone.
b20btec is offline
Old 04-10-2014, 11:43 AM
  #859
NItrox416's Avatar
Excuse me guys,
which differences there are between the screw holes of the 417 topdeck and the 418 one? (a 418 topdeck will fit on a raceberry 417?)
thanks for help
NItrox416 is offline
Old 04-10-2014, 12:48 PM
  #860
Sorry but im not following the barrel washers? Pic? Forgive me Im new to the onroad stuff...
NickGroves is offline
Old 04-10-2014, 02:40 PM
  #861
He's referring to the Flanged Tube's that act like sleeves or liners in the "C" Hubs, see parts BC14 & BC15 in step 16 on page 11 of the 418 manual. The manual says to shim with a 3x.7mm shim though I've had to put in one or two .1mm shims as well to remove some of the slop.
Old 04-10-2014, 03:11 PM
  #862
Yeah I knew qhat you were talking about as soon as you said flanged tubes. Haha. Wasn't seeing it as a barrel. But to each his own.
Old 04-10-2014, 08:10 PM
  #863
b20btec's Avatar
Meant to say flanged but didn't couldn't get the words out.
b20btec is offline
Old 04-11-2014, 10:23 AM
  #864
SuperiorHobbies's Avatar
Default TRF418 In Stock Superior Hobbies.com
Free Shipping Code: SHFREE
SuperiorHobbies is offline
Old 04-12-2014, 06:42 AM
  #865
NItrox416's Avatar
Originally Posted by NItrox416
Excuse me guys,
thanks for help
Nobody can help me?
Old 04-12-2014, 07:34 AM
  #866
Nobody can help me?
I have just checked for you. It won't fit as the 418 top deck is sorter by 2-3mm so the holes don't line up.
Qatmix is offline
Old 04-12-2014, 08:57 AM
  #867
NItrox416's Avatar
Thank you very much
Old 04-12-2014, 07:50 PM
  #868
Based off my tires what would some good changes be? I've only ran these tires two weekends and about 6 times total for about 5mm a piece. We are running 13.5 blinky on medium grip asphalt. I didnt hear them squealing (but I wasnt really listening for it the first day). But the tires really seam like they dropped of quite a bit to the point where im lacking that traction coming off the corner. They are sorex 36 premounted. Its a smaller parking lot track.
And no thats not my 418. I gave the tores to a friend as I was going to pitch them.
First pic is right rear
second pic is left rear
third pic is left front
forth pic is right front
Attached Thumbnails Tamiya TRF418-img_9639.jpg   Tamiya TRF418-img957944.jpg   Tamiya TRF418-img953597.jpg   Tamiya TRF418-img958851.jpg
Old 04-13-2014, 10:37 PM
  #869
Dusttt's Avatar
Trader Rating: 144 (100%+)
anyone know where I can get my hands on part #19804781 stabilizer ends?
not in stock any where it seems
Dusttt is offline
Old 04-14-2014, 12:45 AM
  #870
Nick it looks like you need a touch more camber.
What additive are you using, are you using warmers?
frozenpod is offline
