Like Tree2Likes
Tamiya TRF418
Old 03-12-2014, 07:57 AM
  #721
Originally Posted by NickGroves
What are you guys doing for the stock spur gear? Mine seams to have quite a bit of side to side play in it... is there another manufacturer that fits better? And yes I have all the right shims and in the correct order.
The yokomo BD7 96t spur is also a good fit
Qatmix is offline
Old 03-12-2014, 11:58 AM
  #722
Trader Rating: 42 (100%+)
Default Yokomo spur gears
I run Yokomo spur gears as well. perfect fit.
noworries is offline
Old 03-12-2014, 02:34 PM
  #723
d16dcoe45's Avatar
Originally Posted by VooDooPH
since the ball connector is made of aluminum, you can try drilling it out with a 1.5mm drill bit (either you drill right through what's left of the connector or the friction will turn it far enough so you can turn it with a pair of pliers). hths
I know the 418 uses the taller alloy ball studs but you can just add an extra 1mm shim to 53969 which have the hex head like the alloy ones. These steel ball studs are ALL I run in alloy parts like bulkheads and steering arms & rack on my Raceberry 417:
d16dcoe45 is offline
Old 03-12-2014, 03:15 PM
  #724
Trader Rating: 32 (100%+)
Doh! Sorry. Misread that.
ittjv is offline
Old 03-12-2014, 04:03 PM
  #725
Get the fluorine coated hex balls. Only a small extra cost (200yen RRP)
#54208
cplus is offline
Old 03-12-2014, 05:32 PM
  #726
I had already swapped out the kit ball studs for the fluorine studs (54208) which don't have the 1mm built in spacer.
#54208
See above.
c2tcardin is offline
Old 03-12-2014, 07:44 PM
  #727
Jochim_18's Avatar
Is there a way you convert you 417x to 418?
Jochim_18 is offline
Old 03-12-2014, 08:15 PM
  #728
Not economically I expect. They don't really share many chassis/suspension parts in reality from what I can gather. Lots of little minor/medium changes. Most are interchangeable though.
Good portion of the driveline (diffs, driveshafts) are same or very close.
Suspension is all new for the 418, but connection points and geometry are unchanged.
cplus is offline
Old 03-12-2014, 08:31 PM
  #729
VooDooPH's Avatar
Trader Rating: 18 (100%+)
to convert your 417 to a 418 you'll practically have to buy everything from the chassis and topdeck, all the aluminum bulkheads, steering arms, and all the overhangs (arms, uprights and hubs). not to mention the swaybar parts (which are not yet available) and shock spring adjustment collars if you have ocd. .
most cost efficient way is to get a Smokem/Raceberry conversion kit for the 417 and slap on the 418 suspension bits... not quite a 418 but close.
VooDooPH is offline
Old 03-12-2014, 08:50 PM
  #730
I just had a quick look at the manuals....
I reckon you could keep bearings, turnbuckles, ball cups and hex balls and about 85% of the screws - plus the rear diff and both sets of driveshafts but that is about it!
even the spool is new!
cplus is offline
Old 03-12-2014, 09:58 PM
  #731
Racing4Evo's Avatar
The suspension blocks too...
They are just new stronger revision with the same geometry.
Racing4Evo is offline
Old 03-12-2014, 10:22 PM
  #732
narcotiks's Avatar
Just add more shims until there is no play but the assembly still spins freely... I think I have 0.1 extra in there.
narcotiks is offline
Old 03-12-2014, 10:26 PM
  #733
Well in that case you might as well use the arms as well!
I can't imagine too many people rushing to buy the new blocks when they become available to replace their old stash!
There is a downgrade too - the suspension are shafts are no longer the Ti coated ones!
cplus is offline
Old 03-13-2014, 05:09 AM
  #734
banquer's Avatar
Anybody knows about optionals stabilizer bars?
banquer is offline
Old 03-13-2014, 08:51 AM
  #735
Haven't seen any yet.
