Like Tree2Likes
Tamiya TRF418
Old 12-31-2013, 07:42 PM
  #406
Originally Posted by JimmyMac
You coming out tomorrow to race with us?
Wish I could but in the name of maintaining domestic bliss I'm spending the day with my wife... It's our wedding anniversary! LOL
c2tcardin is offline
Old 01-01-2014, 09:13 AM
  #407
Anyone here know how to get a spare set of the TRF418 staibilsers / rods etc I want to fit them to my sons 417. Or is the 418 the first car to have these new roll bar fittings?
Qatmix is offline
Old 01-01-2014, 12:09 PM
  #408
RC MARKET's Avatar
Some spare parts was arrivals !
RC MARKET is offline
Old 01-02-2014, 04:43 PM
  #409
In general, how do you determine when to change rear diff oil to a thicker or thinner oil?
Is there a too thick or too thin setting?
dizope is offline
Old 01-03-2014, 01:10 AM
  #410
CraigM's Avatar
Trader Rating: 34 (100%+)
I wrote about this and other settings recently on my blog
http://tchub.wordpress.com
Diff: I play with the diff a lot. I always start with 3k (kyosho) at a new track. If I have enough on power grip and entry steering then I will go up which will give more on power steering and corner speed. If the car wants to spin when you apply power or is lazy turning in then you can go down. Iíve never had much luck with less than 2k because it feels like it diffs out, but Iím sure on some tracks or in slower classes lighter oil will work
CraigM is offline
Old 01-03-2014, 01:34 AM
  #411
Fredp1's Avatar
Hi Craig,
If your running blinky 21.5, what do you suggest to start for the diff oil?
Fredp1 is offline
Old 01-03-2014, 03:28 AM
  #412
Originally Posted by Fredp1
Hi Craig,
If carpet I use 1K - 2K with 17.5 or 21.5
Qatmix is offline
Old 01-03-2014, 03:46 AM
  #413
Fredp1's Avatar
One of the tracks I run on is considered as a low grip track. It's a cement concrete track with a painted coating of some sort.
Would you use the same weight oil as used on the carpet track?
Fredp1 is offline
  #414
Fredp1's Avatar
Double post
Fredp1 is offline
Old 01-03-2014, 06:42 AM
  #415
OnRDPassion's Avatar
Trader Rating: 59 (100%+)
With low grip situations I would start with 400wt shock oil instead of the typical 500wt that most are using in high traction situations. Then go from there with either dropping the shocks down a hole or two or softer springs just depending on how the car feels.
OnRDPassion is offline
Old 01-03-2014, 07:14 AM
  #416
Thanks Craig, I forgot about your notes on that blog page and I even carry them in my pit bag. Shame on me.
When you say diff out, what do you mean?
In this particular case, on a non-race day where track prep was lower than normal (sealed asphalt parking lot track), I went from 3k to 1k in an effort to stop the car from spinning out on off-power corner entry and on-power corner exit. The 1k made it way more sensitive. I didn't have time to try another oil so I stood the rear shocks up from 3 to 4 and 4 to 5. This made it better but if I got aggressive, it would still want to spin out.
This is a 17.5 blinky car. It sounds like I should put 3k or higher in but you also say thinner oil may work in slower classes... What would you suggest I try as the next step. By the way, I'm using the kit setting minus wheel shims.
dizope is offline
Old 01-03-2014, 12:12 PM
  #417
CraigM's Avatar
Diffing out is when the diff oil is too thin and on power the inside wheel is unweighted and tries to spin in the opposite direction to the power. It makes the car continue turning or even spin. I've only noticed it with mod when running 2k or less.
Try a 2k diff for 17.5 and move the weight of the car forward to take out the aggression, so run a shorter front wheelbase and longer rear, eg 2mm F and 4mm R - and remember to change your Ackerman by the same amount
CraigM is offline
Old 01-03-2014, 03:03 PM
  #418
Thanks Craig, I'll give those changes a try and report back.
dizope is offline
Old 01-03-2014, 03:21 PM
  #419
bagged69chevy's Avatar
Trader Rating: 22 (100%+)
Craig, can you explain why when i run my tc6, i run a super light diff, 40wt(500cst) and its perfect, but the 418 guys are running such a heavy weight diff oil? 3-5k?
bagged69chevy is offline
Old 01-03-2014, 07:26 PM
  #420
the ae diff doesnt spin as free as the tamiya so it doesnt require the same thickness in oil. very different between the manufactures.
for example, when i drove spec r r1, i used 5000cst oil to get the same feel as tamiya and xray diffs with 2000cst
Bappe is offline
