Like Tree2Likes
Tamiya TRF418
Old 04-01-2016, 06:37 PM
  #2116
rtenzo02's Avatar
Originally Posted by Mini35
Anyone know where I can buy some MR..Roche POM C-blades (part ROC-TRF-07), I can't find any in stock anywhere.
Try hks hobby
rtenzo02 is offline
Old 04-02-2016, 04:01 AM
  #2117
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Has anyone fitted a TRF417 ball diff into a 418?
Dan is offline
Old 04-02-2016, 04:43 PM
  #2118
Yep, fits fine. I also use the ball diff in my 419
Qatmix is offline
Old 04-25-2016, 03:03 PM
  #2119
jdawg81's Avatar
I installed the Fibrelyte low profile shock towers with Tamiya short dampers on my TRF418 over the weekend. I didn't get to do much testing with them but initial results look very promising as the car handles really well. I was able to get TQ after round 1 but I wasn't able to do anymore testing as I had to leave race day early. But outdoor season is starting soon so I'm looking forward to doing some more testing with some Xray shocks mounted.
jdawg81 is offline
Old 04-29-2016, 02:22 PM
  #2120
sonic31's Avatar
Trader Rating: 6 (88%+)
Wadup, I've got the short towers and the shocks but which short spring is everyone using for asphalt high grip?
sonic31 is offline
Old 06-14-2016, 02:40 AM
  #2121
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
A TRF418 has just come up for sale near me. Considering it or a TRF417X. What was the reason for the TRF418 for only being out for a short peroid? Any pros or cons between the two?
Drift_Buggy is offline
Old 02-04-2017, 11:48 AM
  #2122
sosidge's Avatar
Having hardly raced for the last couple of years, the opportunity has arisen again to get some regular club racing under my belt
Will be dusting off my TRF418 - are there any parts I should be adding to it that have become available in that time?
I'm thinking along the line of 419 parts that are backwards compatible and make a big difference.
My 418 has the Samix chassis and a 419 rear diff but is otherwise fairly stock.
sosidge is offline
Old 02-04-2017, 06:53 PM
  #2123
JimmyMac's Avatar
Not really. You racing on asphalt or carpet? I still have my 418 with Samix aluminum chassis and motor mount (racing on carpet). 419 rear diff. XRay short shocks with Fibrelyte short shock towers. The only thing you could possibly look into are the 419 arms with different stiffness. Or some of the hubs f/r. Other than that, not really. Short shocks is where a lot of cars have headed. So that would be something to look into. With the demise of the TRF Team, not sure what else they will or can come up with.
JimmyMac is offline
Old 02-11-2017, 08:13 AM
  #2124
Kyosho Joe's Avatar
What a coincidence. Like sosidge I am also running a 418 in VTA. I was also wondering about/if it is possible to run the super short big bores from the 419x. Will they work with the aftermarket lower upper shock stays mentioned previously in this thread. I assume trf 419 x shock stays won't fit on the 418 at all. So are the fyberlights still available or what other stays can I use?
Kyosho Joe is offline
Old 02-11-2017, 01:37 PM
  #2125
The fibrelytes are always available. (The make them to order).
The wider front end (G or F) blocks and 419X front arms are a good combo for carpet. Although The split blocks will not fit (they changed for the 419) but you can run solid 0.5 blocks on the FR position instead.
Qatmix is offline
Old 02-11-2017, 02:02 PM
  #2126
Kyosho Joe's Avatar
But is it possible to run the super short big bore shocks with the fibrelytes?
Old 02-11-2017, 02:20 PM
  #2127
They were made to fit the X-ray short shocks, the new TRF ones are essentially a Tamiya version. So they 'Should' be good.
I made them as I got a lot of requests. I didn't test them myself. But I have only had positive feedback from people who used them.
http://www.thercracer.com/2016/03/tr...super-low.html
My 418 is stored away so I can't easily check
Qatmix is offline
Old 02-27-2017, 04:53 PM
  #2128
Core Creations's Avatar
Trader Rating: 108 (100%+)
Anyone have an aluminum Samix chassis for the 418?
Core Creations is offline
Old 03-07-2017, 07:28 PM
  #2129
Trader Rating: 28 (100%+)
I have a new samix aluminum chassis and a new set of fiberlyte shock towers. Let me know if your interested.
Bigdaddyswank is offline
Old 03-07-2017, 07:55 PM
  #2130
losibarry's Avatar
Thats a nice car
losibarry is offline
