Like Tree2Likes
Tamiya TRF418
Old 09-15-2015, 01:27 AM
  #2101
Electr0n's Avatar
Is it worth getting a 419 diff for my trf418? Or is there another manufacturer that makes one that would be better?
For Stock 13.5T or lower Yes !
For Modified No ! I switched back to 417/418 diff after destroying the internal gears for the second time during a race.
Never had this problem with the 417/418 diff even with the plastic gears.
Does the 418 come with the big bore shock as box stock ?
No !
Andre
Electr0n is offline
Old 09-15-2015, 01:33 AM
  #2102
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
The problem I have with my diff is its just not as smooth (418 diff). At least compared to my X-Ray. 1k oil in it feels like 3k in most other gear diffs.
I am thinking about removing two spider gears to see if that will help in smoothness. This was a trick that was done on my other car and it helped a lot (Awesomatix).
Dan is offline
Old 11-06-2015, 01:09 PM
  #2103
dc661's Avatar
Trader Rating: 152 (100%+)
in case anyone is looking for a spare chassis I have one for sale here: http://www.rctech.net/forum/r-c-item...ower-deck.html
dc661 is offline
Old 11-07-2015, 06:15 AM
  #2104
niznai's Avatar
The 418 diff is not that bad. I use those along with the newer 419 diffs in my car. The 419 is a bit better.
I use both with plastic gears (metal ones are too heavy) and use shims behind the gears to prevent them rubbing against the case. I also use steel cross shafts. The plastic one is just asking for trouble.
If the diff feels stiff, you might have pinched the o-ring (or didn't lubricate it enough).
You need to shim the out drives and this takes a bit of patience such that you press the o-ring gently and there is no axial play in the outdrive. This means you need to find the right balance of shims on the outside vs inside.
Don't use the xray silicone o-rings as they are too tight and will basically make the diff feel like it has a much thicker oil. They are also too thick and will be pressed down too much hence introduce rubbing un the shim under the sun gears.
Another thing I forgot to mention, you need to sand the back of the gears (all of them) smooth. Use fine grade paper and finish with something like 1000.
niznai is offline
Old 12-05-2015, 12:59 AM
  #2105
Kyosho Joe's Avatar
Could somebody please tell me what brand Spur gears work with the TRF 418???My Kimbroughs are no bingo!
Kyosho Joe is offline
Old 12-05-2015, 02:33 AM
  #2106
Dan
Dan's Avatar
Panaracer (or Yokomo) spur gears work just fine
http://www.tqrcracing.com/shop/produ....asp?p_id=9312
Dan is offline
Old 12-05-2015, 01:24 PM
  #2107
Kyosho Joe's Avatar
Thank you Dan! It is a big help not to have to sift thought all 200 pages of this thread..
Old 01-29-2016, 07:52 AM
  #2108
Mitamiya's Avatar
Trader Rating: 16 (100%+)
Anyone put the 419 big bores on? If so, did it make much of a difference?
Mitamiya is offline
Old 01-30-2016, 05:19 AM
  #2109
vlad_sa's Avatar
Nice to see that 418 is still being driven!
I love mine, smokem chassis, short damper stays, TB EVO 6 shocks in black and 2 x 419 diffs. In stock class it's absolute beast!
Weird to read that some of you had issues with 419 diffs.
I've been running my 419 in midified even since I bought it and not a singe issue with it.
Same with my 418, been using the 419 diffs for a while.
vlad_sa is offline
Old 02-08-2016, 10:53 PM
  #2110
Specv28's Avatar
I have the Samix v2 conversion and love it. Anyone running the smokem low pro shock towers with the samix chassis? With what shocks and springs? Thanks.
Specv28 is offline
Old 02-27-2016, 10:25 PM
  #2111
jdawg81's Avatar
I would like to try the Smokem short shock towers but they seem to be out of stock. If anyone has a set available for sale please let me know.
jdawg81 is offline
Old 02-28-2016, 01:56 PM
  #2112
I will have some really low profile towers ready for the TRF418 in the next couple of days. They are for X-Ray shocks / 20mm springs.
The drawings have been sent so they should be available soon(ish).
Same as the TRF419 ones, they are not for profit, so the price should be similar etc.
http://www.thercracer.com/2016/01/ta...w-profile.html
Qatmix is offline
Old 03-03-2016, 02:23 AM
  #2113
Electr0n's Avatar
Are they ready ?
Andre
Electr0n is offline
Old 03-08-2016, 02:12 PM
  #2114
Yep
http://www.thercracer.com/2016/03/tr...super-low.html
I have not raced them but I have had some feedback from a Malaysian racer with a prototype set.
Qatmix is offline
Old 04-01-2016, 02:54 PM
  #2115
Default Help please
Anyone know where I can buy some MR..Roche POM C-blades (part ROC-TRF-07), I can't find any in stock anywhere.
Mini35 is offline
