Like Tree2Likes
Tamiya TRF418
Old 10-07-2014, 07:42 PM
  #1891
JimmyMac's Avatar
Originally Posted by sosidge
Any recent opinions on aftermarket chassis?
New indoor season is just starting and I just had possibly my worst ever result at a club meeting. I just can't find any consistency for the rear my 418.
Should I try an aftermarket chassis to try and cure my car's vices, or make a clean break and try a completely different car?
Samix and Smokem seem to be my options.
I'm starting from scratch with my 418 but with the Samix Aluminum chassis for 17.5 blinky. What class are you running? I figure I'll give it a few race weekends to see where I end up, but I'm going away from the norm on setups and trying a few different things. What problems are you having with the rear end? Right now I'm working on corner speed.
JimmyMac is offline
Old 10-07-2014, 07:56 PM
  #1892
niznai's Avatar
I would wait and see how many parts are needed to convert/allow to switch between 419 and the 418. There won't be too many and it'll most likely be cheaper than buying the new kit. Right now it looks like it's just the main chassis and the motor mount. There may be more different parts (I understand the diffs are a new design) but I don't imagine they make a difference to setup options. You might need a pair of new belts as well. This is my intention anyway. And my idea is to go with the Yokomo motor mount, old (2014) or new, we'll see.
niznai is offline
Old 10-07-2014, 08:31 PM
  #1893
JimmyMac's Avatar
The bulkheads are wider apart than the 418. They are back in line with the suspension mount holes as they were with the 416. You can see this in the pics of the bottom of the chassis. Since they are wider they will affect the camber link locations on the bulkhead caps. So maybe they changed those too? I dunno but the bulkheads and caps look different.
JimmyMac is offline
Old 10-07-2014, 08:57 PM
  #1894
niznai's Avatar
I see what you say, but I am not so sure they changed the location of the bulkheads. Maybe the suspension block screw positions are different and that's why it seems that way. If it was indeed wider, they'd have to change the driveshaft dogbone length too, and by looking at the pics it seems the blades don't go inboard that deep (in the outdrives) and even if they're using the 42mm dogbone it still looks as wide as the 418. We'll see.
niznai is offline
Old 10-07-2014, 09:20 PM
  #1895
JimmyMac's Avatar
Good point on the suspension mounts, but looking at the pics, the arms seem to be a lot closer to the bulkheads front and rear. The front bumper holes are also about the same position in relation to the front suspension mounts. So I'm going with my wider bulkhead theory.
JimmyMac is offline
Old 10-08-2014, 12:30 AM
  #1896
sosidge's Avatar
I run 17.5 Blinky but I think our carpet conditions are much lower grip than in the USA. The car was fine on the couple of occasions I ran it outdoors but if the grip is low I find it very inconsistent, never sure if the car is going to slide or grip which means plenty of mistakes.
sosidge is offline
Old 10-08-2014, 01:56 AM
  #1897
JimmyMac's Avatar
What springs are you running? Yokomo? HPI? Tamiya? Or something different?
JimmyMac is offline
Old 10-08-2014, 02:18 AM
  #1898
sosidge's Avatar
Currently using HPI but the issue has been constant on other springs too.
sosidge is offline
Old 10-08-2014, 03:23 AM
  #1899
niznai's Avatar
What tires (indoor/outdoor)?
niznai is offline
Old 10-08-2014, 03:37 AM
  #1900
sosidge's Avatar
Sorex control tyre, same for everyone.
sosidge is offline
Old 10-08-2014, 05:53 AM
  #1901
What Sorex do you guys use? I run 32 JB's on my 418 on blinky 17.5 and the car handles consistently. With 28's its more on the edge, but it can be a little faster.
Qatmix is offline
Old 10-08-2014, 06:09 AM
  #1902
sosidge's Avatar
28JBs - but the tyres really aren't the issue as previous cars I have raced have been much more consistent on the same tyres. Hence the question regarding feedback on chassis conversions. The TRF418 just doesn't suit me indoors and it is time for a fundamental change.
sosidge is offline
Old 10-08-2014, 06:45 AM
  #1903
b20btec's Avatar
It's unfortunate you're having a difficult time with the 418 on carpet, the car is a beast on carpet. You may have other gremlins lurking in your setup. I can't say what works for me will work for you, but I've ran the car with standard and short shocks with much success along with different chassis. Standard chassis and short shocks is superb. Short shocks combos are the ride big bore short springs and for standard shocks it's ether the ride haras or Yokomo.
b20btec is offline
Old 10-08-2014, 07:26 AM
  #1904
Trader Rating: 77 (100%+)
I would be happy to share my set up. I am not great but I can tell you my car is dialed. I drive at TQ Raceway and have had help from some super fast guys and they can drive my car as fast as anything around that track. It is med to high bite carpet.
The only extra parts I have outside the stock parts are Yokomo springs front and rear and an Xray servo saver. Otherwise it is everything from the box
Send a PM if you would like.
goin2drt is offline
Old 10-10-2014, 12:25 AM
  #1905
narcotiks's Avatar
New in box 418 for sale.
http://www.rctech.net/forum/australi...8-new-box.html
Willing to ship overseas.
narcotiks is offline
