Like Tree2Likes
Tamiya TRF418
Old 08-31-2014, 08:12 PM
  #1711
Trader Rating: 77 (100%+)
Without reading all 114 pages where would be the best place to order the 418 from? Located in Calif. If I were to get back into onroad (been out for a few years) and coming from a TC6.1 running sportsman 17.5 what extra's are a must or will the kit be just fine and competitive? Lastly, how is it getting parts? and where? I had a nightmare experience running the HB TCX when it first came out.
Thanks for helping a Tamiya newbie.
goin2drt is offline
Old 08-31-2014, 08:29 PM
  #1712
Trader Rating: 32 (100%+)
Originally Posted by Atechbh
What would be a good FDR with the 418. 13.5 blinky fairly small high grip carpet track?
We use 4.0 in 21.5 blinky at same track
It really depends on the motor, but you'd probably be close by trying 4.0 through 4.6. I personally run 4.4 with an Orca 13.5 on a small track.
- Jose
ittjv is offline
Old 08-31-2014, 08:37 PM
  #1713
You can try speedtech rc and tq rc. Both in CA.
I know you didn't ask, but unless you get the 418 for a good price, you're probably better off waiting till December for the 419.
- Jose
ittjv is offline
Old 09-01-2014, 01:18 AM
  #1714
- Jose
speedtech seems to be best price in California at the moment $599
Tower were selling them for <$500 a few months back, but it since popped back up. TQRC doesn't show any kits for sale, but are simply unparalleled in the speed and accuracy of service these days. So for parts, check them out.
I've heard of a few guys selling used 418s if that is of interest.
torg is offline
Old 09-01-2014, 01:19 AM
  #1715
Salkin's Avatar
Question on gearing.
Have replaced a 6.5T with a 4.5T motor. Speedo is LRP Flow Worksteam and X20 motor.
In the X20 motor manual the suggested gearing for a 4.5T on a small/big TC track is 9.5/8.5.
I have observed that most of the pro drivers using a 4.5T motor uses the 116T spur and a 28T pinion. This gives a 7.7 gearing.
So the gearing recommended by LRP and the one used by most pro drivers differ significantly.
Why is this?
I drive on a medium size asphalt track.
Salkin is offline
Old 09-01-2014, 01:43 AM
  #1716
I've found the LRP recommendations are very conservative for the spec motors and have ignored them. Way off.
Wouldn't be shocked if they were miles off for mod too.
cplus is offline
Old 09-01-2014, 02:47 AM
  #1717
Salkin's Avatar
OK, thanks, I will ignore the LRP recommendations and use the gearing, as a starter, that I can find in relevant setup sheets.
Salkin is offline
Old 09-01-2014, 04:06 AM
  #1718
Check Volkers FDR. He uses LRP and seems to know what he is doing
cplus is offline
Old 09-01-2014, 04:57 AM
  #1719
Salkin's Avatar
Yes, of course, I will do that, thanks.
Salkin is offline
Old 09-01-2014, 05:22 AM
  #1720
7.7-8.0 for Volker and co with 4.5's it seems.
cplus is offline
Old 09-01-2014, 05:27 AM
  #1721
Salkin's Avatar
With the spur/pinion size used by most TRF418 team drivers running 4.5T, it equals a 7.7 gearing. Seems in line with Volker and co.
Salkin is offline
Old 09-01-2014, 05:50 AM
  #1722
I've seen as low as 7.15 (116/30) on a Jilles set up.
cplus is offline
Old 09-01-2014, 06:55 AM
  #1723
Trader Rating: 6 (88%+)
for all the people who are not sure the Samix aluminum frame is insane !!! yesterday i test the chassi with a friend who runs with an Associated TC6.2 RSD aluminum frame and is falling in love with the 418 !!!
100g bottom plate totally sit the car on the ground !! quick, fast and awsome corner speed !!!
Quinny45 is offline
Old 09-01-2014, 07:04 AM
  #1724
d16dcoe45's Avatar
Do you think its THAT much better? I was going to start the carpet season off with my regular Raceberry Hard chassis that I've been running on asphalt but now I am thinking of switching everything over to the Samix alloy chassis.
Also--are u running the Samix motor mount & steering brace as well?
Can't wait to try the chassis now! Carpet season starts next Sat!
d16dcoe45 is offline
Old 09-01-2014, 07:07 AM
  #1725
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Lrp 4.5 gearing should be based upon straightaway length. Ask more q on the lrp forum..
hanulec is offline
