Old 08-07-2013, 07:39 PM   #1
Default TA06 Pro Wheel Chatter Issues
Hi All,
I've recently purchased a TA06 Pro not long ago. I'm experiencing some issues with front wheel chatter on full lock and full throttle, it will make the car vibrate pretty hard and I can see my belt getting all wonky. When the wheels are straight or not full lock it runs fine.
It does not do it when the wheels are not on the car either.
Any idea what the problem is?
Thanks,
Will
willzy is offline   Reply With Quote
Old 08-07-2013, 08:24 PM   #2
ThePanda's Avatar
Trader Rating: 65 (100%+)
Are you maxing out the angle on the front cvd axles? On the ta05 which i had that had tamiya cvd axles they were prone to vibrate on full lock.
ThePanda is offline   Reply With Quote
Old 08-07-2013, 08:36 PM   #3
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Thumbs up
Most tc's do this,try turning down your steering epa on your transmitter til it's gone and then tune your cars suspension to get it to turn how you want it to.
skater-deez1 is offline   Reply With Quote
Old 08-07-2013, 09:09 PM   #4
Alright, thanks for the responses.
I'm going to rebuild the front tonight and see if the problem still occurs.
If it still does, I guess I'll just have to deal with it and adjust my steering accordingly.
Old 08-07-2013, 09:18 PM   #5
Trader Rating: 27 (100%+)
It's to expected if you're running a front spool (which you probably are) along with standard cvd's (which you probably have).
On the bench it'll look really bad but it's almost unnoticeable on the track. You could look into some double cardan joints (dcj's) for the tamiya cars and that will eliminate it almost completely if it bothers you. I believe Spec-R makes a 'universal shaft drive' for the tamiya.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 08-07-2013, 09:21 PM   #6
No front spool it is stock
Old 08-07-2013, 09:56 PM   #7
It has a front ball diff?
Old 08-07-2013, 09:58 PM   #8
Sealed gear diff both front and rear.
Old 08-07-2013, 11:12 PM   #9
ThePanda's Avatar
It shouldn't be an issue if it is than get some high angle or double Cardan joint cvd
Old 08-08-2013, 07:28 AM   #10
The front gear diff... Does it have thick oil?
But yea after the rebuild, drive it to see if you notice anything. It won't be nearly as bad as it sounds on the bench.
I'm still using stock cvd's on my xray t3 mod car and while it sounds bad on the bench, it's not nearly as bad on the track.
