Old 06-12-2005, 11:51 AM   #1
Default what do u do if
one of the golden fingers in the servo plug is damaged?
RC12L3a is offline   Reply With Quote
Old 06-12-2005, 11:57 AM   #2
Steve Bahnatka's Avatar
Send a message via AIM to Steve Bahnatka
buy a new plug and solder it on......
SMC-/-JACO-/-PARMA-/-TEKIN-/-CRI
Steve Bahnatka is offline   Reply With Quote
Old 06-12-2005, 12:00 PM   #3
cant remove the whole wire thing from the ESC...too complicated it is.....
Old 06-12-2005, 12:05 PM   #4
Jeff Brown's Avatar
Cut it externally and solder a new plug on. Use shrink tubing on each wire before you solder on the new plug.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 06-12-2005, 01:26 PM   #5
raving-monkey's Avatar
Send a message via MSN to raving-monkey
you can just buy the new plug and the gold pins.
cut off the old plug, strip back the wires and crimp on the new gold pins and put them into the plug.
no need to solder anything.
raving-monkey is offline   Reply With Quote
Old 06-12-2005, 01:43 PM   #6
scoobydo's Avatar
Unless you have a mini Crimping machine, you can never get the pins to be as tight as factory. I always use a tiny bit of solder after crimping.
When I say tiny, I mean miniscule. Just enough to prevent the wire from moving.
If you put too much on, the pins won't fit in the Plug.
scoobydo is offline   Reply With Quote
Old 06-12-2005, 05:58 PM   #7
where can u buy a mere pin?
Old 06-12-2005, 06:03 PM   #8
not sure, but i think the 3 pins and plastic plug is only about $1-$2 or something, i know their about 2 here, lol
Old 06-12-2005, 06:12 PM   #9
scoobydo's Avatar
Yeah, you have to buy a set for the reciever you have. KO, Airtronics, Futuba etc. They are only a couple of bucks. Different companies make them. I usually find them in the Airplane section of my LHS.
Old 06-12-2005, 06:26 PM   #10
Randy Caster's Avatar
Trader Rating: 46 (100%+)
You can most likely send the ESC back to the manufacturer and they can replace the wire for you. More expensive, but done correctly.
