New Setup for Drift and Grip >
Old 08-04-2013, 10:50 PM
Default New Setup for Drift and Grip
Hi guys.
I'm sorry my poor english...
I'm starting at the Hobby, and I tried to learn a few things before start searching the setup.
I want to build a car to Drift (mostly) and to run Grip sometimes.
I don't have anything, so i'll start from zero.
Radio: This one has Lipo battery, i like this. If i buy another car, i'll just need to buy another rx, right?
hobbyking.com/hobbyking/store/__31671__HobbyKing_HK_GT2B_3CH_2_4GHz_Transmitter_ and_Receiver_w_Rechargable_Li_ion_Battery.html
Charger: I thing it is enough.
hobbyking.com/hobbyking/store/__7028__Turnigy_Accucel_6_50W_6A_Balancer_Charger_ w_accessories.html
Charger Supply: To Charger
hobbyking.com/hobbyking/store/__11758__HobbyKing_Power_Supply_100_240v_5A.html
The car:
Chassis: This is the same of Sakura S Zero, just rebranded.
hobbyking.com/hobbyking/store/__25176__Turnigy_TD10_1_10_Belt_Driven_4WD_Touring _Car_KIT_.html
ESC+Motor: I though buying EzRun, but it is just 35A.
aliexpress.com/item/HOBBYWING-EZRUN-4300KV-9T-RC-Brushless-Motor-35A-V2-0-ESC-LED-Program-Card-Combo/862616927.html
I believe this one is a little better. It is Sensored and higher kv.
hobbyking.com/hobbyking/store/__22595__Hobbyking_X_Car_Brushless_Power_System_61 00KV_100A_.html
Servo: BlueBird, is this a good choice?
hobbyking.com/hobbyking/store/__8779__BMS_631_Super_Fast_Servo_5_0kg_10sec_43g.h tml
Battery: Is this a good choice?
hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=21005
Fan:
hobbyking.com/hobbyking/store/__18349__Red_Aluminum_Motor_Heat_Sink_w_adjustable _fan_top_36mm_Inrunner_Motors.html
Pinion:
I don't know which one to use.
Body: I'll buy a simple body, and search for a better personaly.
ebay.com/itm/1-10-Dodge-Viper-SRT10-ACR-X-Painted-RC-R-c-On-Road-Racing-DRIFT-Car-Body-Shell-/171076209865?pt=UK_ToysGames_RadioControlled_JN&ha sh=item27d4efccc9
I ask you to help me, saying if it is good or i can make a better choice.
I what i need to do to change Drift and Grip?
Thank you.
ThiagoSena is offline
Old 08-05-2013, 06:15 PM
ThePanda's Avatar
Trader Rating: 68 (100%+)
If you are brand new then I truly recommend you get a sprint 2, you will get quality parts and get going easier than a kit.
ThePanda is offline
