Old 08-04-2013, 07:56 AM   #1
Trader Rating: 30 (97%+)
Default need help finding the right belt
I currently have the following pulley and belts in my car
center 16t
drive pulley 36t
belt size,
front 123t
rear 106t
I want to put in 20t center pulleys and 37 turn drive pulleys, how would I figure out what size belts will work, thanks
zaraz is offline   Reply With Quote
Old 08-04-2013, 09:26 AM   #2
daleburr's Avatar
You're gaining 5 pulley teeth in total. Approximately half of the pulley teeth are in contact with the belt, so the belts need to be 2.5 teeth longer. Which puts you in a difficult position; you'll have to look at how tight your belts are at the moment plus the amount of adjustment available and make a judgement call between +2 or +3 teeth. Even then you're probably not going to get the ideal tension. Can you go for 19t pulleys instead? Or leave the 36t diff pulleys on.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 08-04-2013, 10:41 AM   #3
I know I would need new belts, not sure what size belts to get, thats what I need help with, the old belts will not work, and I would like to keep the 20t center and 37t diff pulleys, do I just add 5 teeth to the belt, or is there a proper way to calculate the lenght of belt I need, thanks
Old 08-04-2013, 04:58 PM   #4
Jerz616's Avatar
Trader Rating: 49 (100%+)
I would think the xray belts for the t3/t4 would work. They use 20t center and 38t on the diff and spool. So the front and tear belts would prob work.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 08-04-2013, 05:05 PM   #5
Suspended
http://driftmission.com/guides/belts-guide/ Lists pretty much every known belt and its length in mm work out how many mm extra you need then find an appropriate belt to try.
RogerDaShrubber is offline   Reply With Quote
