Old 08-03-2013, 06:27 PM   #1
Default Lrp Sxx tc v2 help please
Hi all,
Put my lrp Sxx tc v2 in my t4 today. It is starting and stopping very quickly. Can't even use it. I've checked the manual and its next to useless!
Has anyone had any experience with them?
Do I need to plug it into a lrp interface into the laptop and reset it? Or is there a process of pressing buttons I can do?
I have a 15.5t sensors motor in it so that's not a problem.
Any help would be great on this matter! It's very frustrating!
Thanks in advance all
Mwdynamics is offline   Reply With Quote
Old 08-03-2013, 06:55 PM   #2
Trader Rating: 20 (100%+)
What is it doing?
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 08-03-2013, 07:04 PM   #3
It's accelerating then stopping quickly repeating. So start stop start stop constantly when everything in tx is turned on
Old 08-04-2013, 07:14 AM   #4
tc1
Trader Rating: 15 (100%+)
Sounds like its set wrong, Set all your endpoints on the radio to 100 and re-calibrate it to the radio. If that doesn't do it, the manual has a procedure for doing a reset of all adjustments. Hope it helps!!
Travis
tc1 is offline   Reply With Quote
Old 08-04-2013, 07:40 AM   #5
Travis
Thanks travis,
I've followed the manual for the radio/speed controller setup and still having the same issues. I don't know what else to do apart from purchasing a USB interface and going through the settings on the laptop. Would that be the next step? I've never used the USB interface before
Old 08-04-2013, 10:28 AM   #6
The USB interface won't help you. It' pretty much only allows you to load different firmware on the ESC. It might solve your issue by reloading the firmware but I seriously doubt that. I think you must have bigger issues with the ESC or your radio.
Old 08-04-2013, 02:16 PM   #7
Ok Troy, thanks for that. I may get a USB and reload the firmware. I've tried resetting the min max on throttle so hopefully that will work
Old 08-05-2013, 09:40 AM   #8
Turns out that I have a nackered board. Off for a upgrade now! :-(
