Old 06-09-2005, 04:53 PM   #1
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Default Sticky Track ?
Just asking your guys opions on what makes for the best stuff to spray on an asphalt track to get it nice and sticky. Looking for any type of stuff cheap or expensive. Just want to see what others are using at there tracks. I heard the stuff they used at the Reedy Race was inexpensive and very good.
So if anyone has input on what you use please give the name and how you mix it and cost.
wallstreet is offline   Reply With Quote
Old 06-09-2005, 05:29 PM   #2
axel's Avatar
root beer and water
axel is offline   Reply With Quote
Old 06-09-2005, 05:42 PM   #3
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
VHT
dontfeelcold is offline   Reply With Quote
Old 06-09-2005, 05:44 PM   #4
Hebiki's Avatar
Trader Rating: 26 (100%+)
at a TCS race.. the guys bought about 10 2liter bottles of root beer. stabbed the side/bottom with an xacto knife....and WALA! instant sprayer. we applied it on the track..and the traction was great!!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-09-2005, 05:44 PM   #5
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
VHT $18 / quart i think
mix with gas 1:3 (not sure here)
lots of grip, makes for high tire wear. It's pain to spray and smells nasty.
crimson eagle is offline   Reply With Quote
Old 06-09-2005, 05:58 PM   #6
NVisible's Avatar
and no doubt does wonders for the environment.
Club here sprays suger & water, but id imagine root beer/coke or any syrup based soda/pop would do the trick
NVisible is offline   Reply With Quote
Old 06-09-2005, 06:23 PM   #7
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I bought a gallon of VHT locally for 20 bux and then bought 8 liter bottles of alcohol (rubbing-not drinking) and sprayed it with a mix of 2 (alc)to 1(vht), but in the enda ton of root beer and grape soda was better traction. I used about 30-36 liters on a 75x125 track.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 06-09-2005, 06:39 PM   #8
As I recall we started cutting it with denatured alcohol, rather than gas.
Old 06-09-2005, 07:05 PM   #9
Chris08527's Avatar
Trader Rating: 16 (100%+)
at my local track they use VHT and cut it with denatured alcohol 50/50
was like fly paper this week . . .
Chris08527 is offline   Reply With Quote
Old 06-09-2005, 07:12 PM   #10
wallstreet's Avatar
Whats vht ?
Old 06-09-2005, 07:30 PM   #11
kyle "hitawall"'s Avatar
i don't nkow what it is but it is sticky!!!!!!
i know they use it at drag strips.
at the track i race at that they vht. they either use 50:50 or a
75(denatured alcohol):25(vht). they put on a heavy coat first and
then as the day goes on they apply thin coats in the corners.
thracion is good.
RCAmerica|Xray|Hudy|Jaco|EPIC
kyle "hitawall" is offline   Reply With Quote
Old 06-09-2005, 09:17 PM   #12
Whats vht ?
This stuff
http://72.10.43.141/trackbite.htm
Obviously tracks are using this stuff, but its so sticky its hard to believe the cars even move. If you have ever stepped in it, it just about ripps your shoes off.
3434 is offline   Reply With Quote
Old 06-09-2005, 09:23 PM   #13
edseb's Avatar
Grape soda is pretty good or sugar water. I have heard a lot of peopel don't like VHT though, since it isn't as consistent. It gets grippy, but causes people to chase the track all day (well more than normal). Just go with sugar water, it's also cheaper.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 06-09-2005, 09:43 PM   #14
VHT ..... this is what I use on our parking lot track. Good stuff on a track where you don't have to worry about wind bringing dust and dusting the track. At that point it gets pretty loose. Cut 1:1 with mineral spirits or methanol cost 20$ a gallon to spray don't use gas to cut it's bad for your asphalt
Sugar water (karows corn syrup)...... this is what we use at one of my tracks and is what they used at the Reedy Race. I mix it about 4 parts water to 1 part corn syrup. Great traction very sticky. You want to spray enough for the track to get wet. On our track about 100'x70' I spray around 10 gallons.
If your track temps get over 135 deg for extended periods of time and your running nitro cars then you'll probly want to run VHT. Sugar water/soda turns into M&M's and seals the asphalt up so well that the lubricants from the nitro fuel will sit on top of the candy coating making for one lose ass track.
Hope that helps. BTW cost of soda is about half of VHT but if you can still get a 55 gal drum of corn syrup this would be the least expensive of all. The biggest thing on spraying your track is make sure it's blown off very well and be consistent with the spray.
Ruben
schurcr is offline   Reply With Quote
Old 06-09-2005, 09:50 PM   #15
I race at several tracks that use a variety of substances to bring up the traction.
1. Methenol/VHT w/ 3 to 1 mix=traction is great and tire wear is excellent, but chemicals cost alot of money to coat a big track surface.
2. Cheap 3 liter grape and rasberry soda=traction and tire wear is good when compared to VHT mix but alot cheaper.
3. Corn syrup/water/1 bag of confection sugar=traction was very high and tire wear was better than excellent.
Different tracks but with similar grades of asphalt, tight and smooth. I must say that the best and most cost effective traction compound was #3.
Just my take on the matter.
Jamie Corrado is offline   Reply With Quote
Rules Sticky oXYnary R/C Tech Site Forum 16 08-18-2008 08:47 PM
RB 523 STICKY CARB! mcheck R/C Tech Site Forum 0 01-11-2008 06:22 PM
Can we have an FAQ sticky???? BritRacer Painting, Designs, Graphics and Photography 1 11-29-2005 03:12 PM
Sticky solder? josh69162 Electric On-Road 18 11-04-2005 12:55 AM
Sticky? Platinum_Racing R/C Tech Site Forum 1 09-20-2005 06:50 PM
