:confused:Please help. Lipo charging question
Hello, I just bought a 25c 2s lipo and i also bought a balance cahrger - http://traxxas.com/products/parts/ch...ipo2s3scharger I was wondering if it is okay that i chaerge the lipo with this charge only and not a normal charger? Thanks
yes it will works fine
But ,
this charger is only design for 1400mAh (#2823) and 2200mAh lipo
but it will take an hour or more to full charge ...
if you are going to upgraded the lipo ..I would get the normal charger
So it will work perfectly fine charging it only with that balance charger? Also the battery i have is a 4500mah battery so it will take about 5 hours to charge but i don't mind the wait. So is it perfecly fine to use that balance charger every time i charge it?
core rc make a great charger thatll only take an hr to charge and there relatively cheap
5hrs to charge? youll soon get tired of the wait
Nah, I already have to wait 8 hours to charge my NiMh. So 5 hours is a fast charge to me and how much is the charger that you are talking about?
http://www.apexmodels.com/gbu0-prodshow/CR161.html
If the charger has a fault and overcharges them, they will burst into flames (a bit like an oxy-acetylene torch) and will burn anything close.
That is the reason i prefer to charge at the full 1C rate so i don't have to leave them unattended for more that an hour.
Just a note, unlike NiMh batteries, i wouldn't go leaving lipo's on charge without being there all the time.
I would use caution with those small Traxxas chargers. Recently I received 2 of them with 2 new Rustler VXL's, and even though I have several really nice DC chargers and a 1000watt power supply, I thought I would try them, just because I like testing stuff. BOTH of them did not charge correctly. One of them smelled of burned electronics during charging, and ended up overcharging the battery to 4.29 volts on one cell, and 4.19 volts on the other cell. (Lipos should be charged to no more than 4.20 volts per cell).
The other charger worked one time fine, and charged a battery to 4.18 and 4.19 volts per cell. The second time I tried to use it, it overcharged both cells to 4.26 volts, which is unacceptably overcharged.
If I were you, I would throw those small Traxxas chargers in the garbage immediately before you ruin a good Lipo battery, and pick up a Thunder AC680 charger for $50.00 from HobbyPartz. I have had very good luck with Thunder chargers, and would highly recommend them to anyone on a budget.
