Old 06-07-2005, 01:29 PM   #1
axel's Avatar
Default ESC choices
Hi,
I'm interested in replacing my lrp sports esc for a new esc. I'm either thinking about the ko vsf-1, lrp comp2, or the novak gtx. I don't know what features each one has nor do i know what they do. I'm a big newbie when it comes to speed controllers.
Thanks,
Axel
axel is offline   Reply With Quote
Old 06-07-2005, 02:07 PM   #2
Charles Godwin's Avatar
The vfs-1 you can program with a setting adaptor or a computer, the vfs 2000 is just as good just a little bigger and a few less setting options but still is very good
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 06-07-2005, 02:13 PM   #3
axel's Avatar
What else can you adj. on the vfs-1 besides throttle and breaking...well i mean what are the specifics of these adj.?
Old 06-07-2005, 02:14 PM   #4
Default novak GTX
go with novak you cant go wrong with there customer service.. the NOVAK family of speedos are allways on top....
lickrim is offline   Reply With Quote
Old 06-07-2005, 02:27 PM   #5
axel's Avatar
Never really understood the adj. of an esc...does it just control how much throttle and breaking you want?
Old 06-07-2005, 02:29 PM   #6
Send a message via AIM to adootindotin
get the NOVAK, it has all the adjustments you need and more, it's reliable and the factory support is great
adootindotin is offline   Reply With Quote
Old 06-07-2005, 02:33 PM   #7
axel's Avatar
Not to mention it's cheaper than the vfs-1 and lrp comp2, but i'm a huge ko fan, but i'll probably just need the novak anyways.
Old 06-07-2005, 02:36 PM   #8
wannabee's Avatar
Anyone hear this: When using the LRP Q2 and a digital Ko servo and PT the Spektrum won't work??
Just something to think about if it's true....
KE
wannabee is offline   Reply With Quote
Old 06-07-2005, 02:38 PM   #9
Eldaddio Fozzy's Avatar
LRP QC2 they are awesome, or a maybe you should think about a Keyence they are little more expensive but are worth it. I use both of these speedos are they are the business
Eldaddio Fozzy is offline   Reply With Quote
Old 06-07-2005, 02:41 PM   #10
axel's Avatar
The Keyence esc is really a high end esc that i probably don't need yet. The vfs-1 though has alot of features that i can program.
Old 06-07-2005, 04:32 PM   #11
cartmen34's Avatar
KE
Not exactly, but kind of.
Lemmie 'splain it to you...
-The QC2 doesn't output the same level of voltage other speedos do.
-The spektrum receiver requires more voltage than 'standard' receivers do.
Therefore......
-The spektrum receiver doesn't receive the voltage it needs when trying to power itself and other voltage demanding parts, like a high-end servo.
Therefore......
glitching may ensue.
THE FIX? Get the 4700 capacitor. It owns all. See the spektrum thread for more info.
cartmen34 is offline   Reply With Quote
Old 06-07-2005, 04:50 PM   #12
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Novak ESC's are good. I like Keyance personally. I've been running them for about 6 months now. I ran Novaks before then. If it's adjustability and reliability you need, Keyance is the way to go IMO. Plus, Schumacher USA is the importer here in the Sates for them and it'd be hard to beat the sevice Adrian, PW, and Troy give if for some reason you do ever have a problem.
Jon Kerr is offline   Reply With Quote
Old 06-07-2005, 05:06 PM   #13
dakrat's Avatar
if i have to buy another esc, that would be the novak GTB especially bushless are getting popular nowadays. run either brush or brushless
dakrat is offline   Reply With Quote
Old 06-07-2005, 08:51 PM   #14
Still Bill's Avatar
KE
I am one of the people that had this incompatibility problem with these three components which made me switch back to an Airtronics 94357 servo to resolve that problem. The 4700 cap didn't resolve anything in my case.
Spektrum has now updated both of the boards in my original receiver; so, I am not sure if that issue remains. Will test it to find out sometime.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 06-07-2005, 08:54 PM   #15
wannabee's Avatar
Bill
RBlove, had this same problem, sucks I like the KO servos!
Thanks a lot for the reply!
Kevin
1/8th Choices... hmm BlueStreak362 Electric Off-Road 20 11-14-2006 11:59 PM
New To R/C...Bad choices? zracer196 Electric On-Road 51 03-17-2004 12:48 PM
choices choices choices donthaveaclue Rookie Zone 4 11-27-2003 07:08 PM
choices choices choices donthaveaclue Nitro On-Road 11 11-26-2003 03:30 AM
choices choices choices donthaveaclue Monster Trucks 1 11-25-2003 07:05 AM
