Hara Twister 2.1 >
Hara Twister 2.1
Hara Twister 2.1
Old 06-07-2005, 10:57 PM
  #16
Trader Rating: 17 (100%+)
nice speedo too bad got the twister 2 not 2.1
EngTat is offline
Old 06-08-2005, 11:44 AM
  #17
Yes Twister 2.1 bester
instock now !
HKRCMODEL is offline
Old 06-08-2005, 12:43 PM
  #18
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by John Fontaine
Looks good, but why is the switch so big?
Hey John, the original VFS-2000 had the "push button" switch. while it was smaller, it made it difficult for some to properly program their escs. so with the VFS-1, VFS-1C, and VFS-2 line of esc's.. Ko Propo decided to separate it into two separate switches. one for turning it on and off, and one for programming.
Hebiki is offline
Old 08-30-2005, 04:06 PM
  #19
Hey guys is it true that to use this Twister 2.1 with a 21 turn motor i need to program it cause it is designed to work on low turns motors ???
Thansk for looking
speed6 is offline
Old 08-30-2005, 05:30 PM
  #20
josh69162's Avatar
Thansk for looking
I wouldn't be super suprised. Hara wouldn't be caught dead with a high turn motor...
-Josh
josh69162 is offline
Old 08-31-2005, 01:30 AM
  #21
so i would need a programmer to get the out most to be used with a 21 turn motor or it would run pretty fine.
speed6 is offline
Old 08-31-2005, 01:59 AM
  #22
Geetoo's Avatar
Twister 2.1 feels a lot better than my previous speedos. Lotsa punch, mid and top end. Unbelievable, never had that power before. I had to tone down the hara profile to take off the wheel spin on an 8 turn motor (track was abrasive). I was a "non ko believer" before...not anymore!
Geetoo is offline
Old 08-31-2005, 02:10 AM
  #23
Anyone know how well a 19T will work w/ the hara profile? too soft? too hard?
If I was to use the hara profile, what kind of gearing would I need w/ a 19T?
rcnewb2004 is offline
Old 09-06-2005, 11:54 PM
  #24
Geetoo's Avatar
-Josh
He used Orion Hara V 6turns at the Reedy
Geetoo is offline
Old 01-27-2007, 06:20 AM
  #25
part-time racer's Avatar
Fitted the 2.1 bask into my car yesterday as it got some water damage in the summer and i left it in airing cabinet to dry it out.
With everything switched on the speedo is fine but when i turn the speedo off the motor starts at about half throttle? So i turn the speedo back on again and it's ok again.
If i turn my transmitter off and leave the speedo on, it's ok.
Has anyone seen this problem before?
part-time racer is offline
Old 01-27-2007, 01:49 PM
  #26
Sean T Guy's Avatar
I know this may sound stupid but have you checked all your wires into the reciever are the right way round and in there correct location.
Sean T Guy is offline
Old 01-27-2007, 03:17 PM
  #27
Wing Chun's Avatar
What I have found is if you contact Robert at KO and discribe the problem he will tell you if it is serious enough to have to be sent to Ko for repairs. He is great to deal with and fast.
Here is his email
[email protected]
Good luck
Addam
Wing Chun is offline
Old 01-27-2007, 03:26 PM
  #28
Thanks mate, I'llsee how I get on with it tomorrow.
