ETS Round 6 - Hudy Racing Arena
#212
#213
#214
He mentioned that some of the drivers in appledorn ran or showed up with a different endbell on the motor. that was an obvious change and the most people go the easy way, like different end bells, mod rotors or different stators.
All this can be figured out after the race or in case of a complain.
#215
Here I have an original sensorboard:
Tell me what is wrong with it
(some people doing technical inspection could not tell...)
Cheaters are inventive and if technical inspections do not have all experience and tools to find the modifications then cheating is really simple.
FET's or FET-boards are changed within the Cytrix ESC, there is a huge talk about a same looking GM rotor with better performance, internal pulley ratio is fooled with pulleys from other brands, even blanco gears get a different number of teeth stamped on only to fool the FDR calculation. In that last case all gears and pulleys have to be counted to be sure, no technical inspection will do that because the needed time and efford, only in real suspicious cases. And the list of possibillities goes on.....
Not to mention the different motors SP is producing, the latest version seems to run some 1000 rpm more... SP should give new versions new article numbers so they can not be used biside older motors.
Regarding detecting rotors I also have made a tool to test the strength of the magnetic field:
Just a 20 euro costing device showing differences in rotors which can be translated to the performance of the motor. The highest readings on this tool were actually the fastest motors. On a scale of 1000 the largest differences between several original rotors was just 3 to 4%
And to be honest, the SP motor is the worst motor in design making huge tolerances from itself and giving lots of room to "make" larger tolerances.
+ YouTube Video | |
#218
We have to give the best drivers in the US a platform to challange each other at a monthy basis. To close the gap to europe and Asia. I'm talking about Stock and mod.
How we can get an US driver on the top of the WC podium without a challanging field like the ETS.
We need 1 or 2 stock classes and open TC.
But this will not work without manufacture support, specically the US based ones.
#219
Yes the hall sensors are advanced, probably a degree or 5.
#221
And therein lies the issue with spec motor, fixed timing and fixed FDR. Now, not only do we have to worry that some motors aren't wound equal to others, but also that the placement of the hall sensors by the SMT machine might be better on some boards than others.
It's a shell game. You can move the problem around, but it's always there. The best we can hope for is to try and find a balance.
#222
Again, such a simple thing can be overlooked, for sure if technical inspection does not have a list of how to detect all kind of illigal mods.
#223
I think it would work if you made an east vs. west and meet in the middle at hobbyplex in Omaha or Mikes for the true National nice and in the middle.
I can name a handful of tracks and wouldn't mind going to 4 races to make a points series with points and then a National in the middle. National race being a 5th race. Just like Ama supercross style. Have the top 20 guys etc from each side race against each other. Then take the top 5 and do a east vs. west race. Make it real interesting by adding some cash prizes to promote the racing. Do a dash for cash just like over there.
Any thoughts? Try to make the 4 races a two day race to keep vacations and travel down.
#224
Suspended
Maybe in your area mod is dead but its still alive and growing here in Texas. We just had 14 guys in our last Texas Series race and those are just the hard core guys that travel. And yes, most of them are well known racers from years past or up and coming drivers. There are more than 5 of us!
#225
I don't think that 13.5 is popular enough to consider it a class for TC. I personally think mod and 17.5 tc. Then maybe a catch class for 12th since it seems that not enough guys run mod something like a 13.5 open esc. There are more than enough tracks to run 2 track outdoor and 2 track indoor.
Mod needs to go. It's holding us back. Sorry it didn't work out.
