Battery specs
Battery specs
hi,
on the back of batteries there is the label with the specs. i have noticed with the IR some say 14-18 and others 2.0-2.7. What is the difference between them? is an IR of 14 as good as an IR of 2.0?
thanks
thanks
the lower the internal ressistance the better!
thanks for the replies guys. what do you mean by 'the number'? what would IR of 17 work out to? is that good?
IR of 17 is way high. The highest I'd go for if the IR's are in the teens would be 15. Most of the packs you'll see from Fukuyama will be in the 13-14 range. I have some 12's. IR (Internal Resistance) relates to how quickly the cells can get power to the motor which translates to more punch.
The way i understood it was some IR #'s are a pack total IR and the other is the cells individual IR.
A PACK of
14IR pack = 2.33IR per cell
So if you buy brand new packs that claim 2.2IR per cell when you cycle the pack as a pack on your T35++++ your gonna be looking for an IR of 13.2.
A PACK of
That's true on the turbo 35 but when they match cells, they do it individually, not per pack. They cycle each cell in Turbo matchers ( I believe it's 4 or 5 cells per matcher, I can't remember for sure), print the labels for each cell, then match them up by voltage, runtime, and IR into 6 of 4 cell packs. Some matchers just use a little different software that gives a higher number for the reading like Fukuyama does.
It's an average internal resistance if I'm not mistaken. You can Email Dan from Fukuyama. I'm sure he'd be happy to get you an answer. [email protected]
