Old 10-17-2005, 09:45 AM   #31
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
i ran the new G6 PF pontiac
man it was a hand full (rubber v-tech24r on carpet)
turns in real nice but on fast sweeper would break away if pushed hard
car looked real smooth going around but if i tryied to attack the track the car would bite back
craig drescher was trying to help out also, he said it looked real smooth & good
but man it was so on the edge
bigger wing?? maybe confusing day really
we changed the car big time through out the meeting but was still.5 sec a lap slower then top man (forgot who that was )
missed the A by 3/10th sec pole in the B & won it
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 10-17-2005, 10:06 AM   #32
teamgp's Avatar
Have you tried lowering the rear roll center? This plus raising the rear ride height .25mm might work to calm the rear end down, without loosing steering, with that type of low downforce body. Raising the rear ride height above the front produces more downforce for any body. Not only will it raise the rear wing up into the airflow more, but the low pressure air pocket underneath the chassis will be increased and therefore suction the car to the track.
What was the full setup?
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 10-17-2005, 11:47 AM   #33
Send a message via AIM to odawg315
Originally Posted by Soviet
Maybe you thought the car looked better and thus you drove better.
just kiddin'.
very possable, maybe the glare hit me at a different angle which caused a slight tingle in my trigger finger that made me get off throttle a little to soon!!
odawg315 is offline   Reply With Quote
Old 10-17-2005, 12:04 PM   #34
teamgp's Avatar
I still think you folks are imagining things in your heads when you try to tell others your various reasons why Jellybean "A" "is better than" Jellybean "B."
All modern TC bodies are the same generic shape. You can make any modern TC body feel just like another one just by playing with lower lip and wing position/area.
Not so. With respective optimal setups and a consistent driver, Jellybean "A" will be consistently faster than Jellybean "B". Unless its black licorice, since they are, or at least should be, illegal in any form.
Although you may be able to get them to "feel" similar on the same surface and with the same tires, one will most likely be consistently faster than the other.
Guy Hood
Old 10-17-2005, 01:18 PM   #35
burgboyz's Avatar
Trader Rating: 70 (100%+)
Default body design
1. Get a box of cereal, eat cereal.
2. Cut out the back of the box
3. Cut 4 holes in the other side
4. Mount
5. Run new body and start 10 threads about how "dominant" your new Trix 5.0 body is on carpet, but sucks on tarmac.
There...y'all happy now?
Laugh all you want however...
Downforce and drag are proven facts and a little or alot are molded in differently on bodies. Make a few practice laps with one, then switch to another and you can see the difference. Switch wings or cut one down and try this basic experiment again. In the end it is your choice!!!!!
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 10-17-2005, 02:12 PM   #36
MR JOLLY's Avatar
we were at aloss
we done everything to get the car `safe` droop,roll centres,oil`s,shock positions,roll bars,castor,springs,
felt like flogging a dead horse
only thing we didn`t change was the shell , so the nemises is out on weds night, same rubber & carpet racing
but i watched craig swap shells between races to tame `he`s ` car
so shells do act differently on track
i know one who only uses PF vectra shell every where
Old 10-17-2005, 03:14 PM   #37
TryHard's Avatar
Agreed.
Switched between a Mazda6 and a Ride Mk2 stratus mid-run this weekend (in practise). Started out with the mazda, then switched to the ride. Ran for 3mins with each (only doing stock), and I have to say the Ride was better for me, made the car more stable on the rear, compared to the mazda. With the Mazda the car would tend to turn in, then start to break away. With the ride, this didn't happen, and I was more confident with the car as a result.
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-17-2005, 05:18 PM   #38
Soviet's Avatar
At 1/10th scale nonetheless.
All I've ever really meant to express is that folks don't need to buy into the "body of the week" craze. I'm sure Dale Epp would disagree though.
Yes, some bodies are more draggy than others. Say CTS vs NEMESIS. Especially since the CTS has such a blunt nose. Since a body has a more blunt shape it should provide a "bit" more downforce on the frontend.
It's all fair game at the rear end of the body though. As you could make any body feel just like another one by playing with wing-area and position.
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 10-17-2005, 05:20 PM   #39
Soviet's Avatar
Good to see ya Guy!
I should be up there this Sat. And speaking of bodies, I'm whipping one up tonight.
-Sean
-Me
Old 10-17-2005, 06:29 PM   #40
burgboyz's Avatar
Agreed!!!!!!!!!!!!!!!!!!!!!!
what body are you doing tonight?
nicole or jessica?
Got Droop???
Old 10-17-2005, 07:21 PM   #41
Soviet's Avatar
nicole or jessica?
Oh man....like you even had to ask?!?!
Nicole of course.
Actually I'm doing up a Nemesis.
-Me
Old 10-18-2005, 01:05 AM   #42
MR JOLLY's Avatar
Originally Posted by TryHard
Agreed.
Ed
drescher hinself said the mazda is to steery ideal for foams ,but rubber on carpet/asphalt it`s all about balence
soviet
your right also
buy the new shell as soon as it comes out coz it`s mile better (not) , not all shells work coz they are new
this is properly why dodge 2 is still going strong
Old 10-18-2005, 07:50 AM   #43
teamgp's Avatar
Good to see ya Guy!
-Sean
Just as long as you don't whip up on me with it Saturday.
Guy Hood
Old 10-18-2005, 07:53 AM   #44
teamgp's Avatar
nicole or jessica?
I certainly hope neither are "draggy" as Soviet says.
Guy Hood
Old 10-18-2005, 09:38 AM   #45
Soviet's Avatar
No way...I'm gonna be chasing you folks for a few weekends to come before I find the pace.
That I'm SURE of...
Although I may have the prettiest car out there though.
-Me
Carpet Touring comparison bo54 Electric On-Road 15 01-04-2008 12:28 PM
Touring Car Body luismx123 Painting, Designs, Graphics and Photography 5 09-30-2007 09:07 AM
WTB Tamiya Touring Car Body dragracer72nova R/C Items: Wanted to Buy 1 02-21-2007 09:18 PM
Comparison of Tamiya RC Touring Cars cyber3d Rookie Zone 1 08-25-2006 02:52 AM
DaHellion touring body Dreddlox Nitro On-Road 45 11-22-2004 01:01 PM
