Stripped Screw
Old 06-07-2005, 07:51 AM
DIMO's Avatar
Default Stripped Screw
Hey guys i have an Fk04 and whilts working on it i somehow strupped the screw on the top deck on the front left bulk head, does anyone have any tips on how to get these out without causing damage to the car
DIMO is offline
Old 06-07-2005, 07:54 AM
raving-monkey's Avatar
try sticking a 5/64 imperial allen driver in there, iirc it is slightly bigger and should fit in there tightly
same if you strip a grub screw in a pinion, use a 1/16 allen driver.
raving-monkey is offline
Old 06-07-2005, 08:21 AM
DIMO's Avatar
Default D'oh
Thanks for the heads p dude, but wat if that dont work
DIMO is offline
Old 06-07-2005, 08:25 AM
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Take a dremel with a cutoff wheel and put a slot in the screw head. Then use a small flathead screwdriver to get it out.
-James
JamesArluck is offline
Old 06-07-2005, 08:27 AM
you can get those counter drill bit that will grab the screw and unscrew it.
check the sears or home depot.
i think it is call Craftsman 3 pc. Screw-Out™ Damaged Screw Remover Set.
~Ming
aoizip is offline
Old 06-07-2005, 09:19 AM
Hi,
I had the same problem. I did the dremel trick as said by JamesArluck.
This is very easy, and gives a neat result.
Replace the screws by steel ones made for the original T1. These screws are much harder.
Bye Thomas
840918001 is offline
Old 06-07-2005, 09:33 AM
~Ming
oh yeah i forgot about them.....you have to drill a small hole first though..so if the screw thread is 3mm (like M3 screws) then do a 2mm/2.5mm hole
over here in the UK they are called stud extractors.
the threads on them are the wrong way so when you go to unscrew the stuck screw, the stud extractor will actually get even tighter and it will pull the screw out...reeeeealy useful.
Old 06-07-2005, 02:23 PM
PlainOleDave's Avatar
Trader Rating: 14 (100%+)
raving-monkey, They (Craftsman) also make a reverse cutting bit that You would simply use reverse to 'drill' out the screw. When it 'bites' enough, the screw will loosen and the bit acts as a screw-driver.
PlainOleDave is offline
Old 06-07-2005, 02:28 PM
newracer's Avatar
you can glue a cheap "L" allen wrench into the screw with CA, let sit overnight, then remove it
newracer is offline
Old 06-07-2005, 02:39 PM
I dunno how much room you have... but try removing all the other top deck screws, and then turning the whole topdeck in an effort to get the screw loose.
MartynD is offline
Old 06-07-2005, 02:46 PM
i was thinking that but i think the top deck is sort of 'sunk in' to the bulkhead..well it certainly was on the evo2 i had, not to sure about the FK04...you could give it a try though, it should work.
Old 06-07-2005, 02:57 PM
wannabee's Avatar
That or solder a cheap allen wrench into it. The heat sometime will loosen any thread lock too. Works everytime, may take a few trys to get the "bond" right...
Good luck!
KE
wannabee is offline
