help quasar pro setting
can someone help me..
i have my quasar pro charger version 1 and i have 1700 & 3300 packs... can u tell me what is the right settings for each packs... AMPS, DISCHARGE, TRICKLE, THRESHOLD, ETC...... thanks in advance....
Before doing anything else, check to see if you have the version 2.1!
Due to a potential safety concern, there is a voluntary recall of the Reedy #611 Quasar Pro Charger.
Two problems, a defective fuse and a program error, make the charger unsafe to use, particularly with high capacity NiMH cells. On rare occasions, an internal component failure, or an external electrostatic discharge event ("Carpet sparks"), can cause the charger to overcharge these battery packs. This can result in leakage, overheating, or even explosive separation of cells in the pack.
This recall applies to all #611 Quasar Pro Chargers manufactured up to March 1, 2004. They can be identified by any of the following:
1) Display shows "QUASAR PRO VERSION 1.0" when first turned on.
2) No barcode label on the underside of the charger.
3) A barcode label on the underside with the numbers "611" or "611A".
If you have this charger, you must discontinue its use immediately, and contact Associated Electrics, Inc., to arrange for corrective service at no charge to you.
Corrections for the problem have been developed and tested. New Quasar Pro chargers, and chargers that have been corrected, are designated #611B, and display "Version 2.1" when turned on.
help
any tips about the settings.....
Amps: 5.0-5.5 amps
Discharge: 20 amps
Trickle: off
Threshold: .03 mv
Cycle: you don't really use
Delay: you don't really use
help
thanks for that one....
any other settings....
Originally Posted by grazianos
The above settings should work for 1700s, just change the battery Mah setting. Are there any other settings you are unsure about?
bcoz other says that threshold setting should be 8mv/c.......
if u we're to charge what will u use?
help
what is the difference between the ver1 of quasar pro and ver2.1???
please tell me... tnx
