Old 06-05-2005, 12:31 AM   #1
loopedeloop's Avatar
Default suspension 101
I noticed that on these forums theres a lot of people who like myself know the terms but not the effects that changes to suspension settings will likely have.
eg raising and lowering roll centres, what will it do?
or spring weights
Maybe some expert could help out??
Cheers
geoff
loopedeloop is offline   Reply With Quote
Old 06-05-2005, 08:03 PM   #2
Interesting that you should ask this. After 1 minute at Google I had
http://download.teamassociated.com/p...HandbookV2.pdf and http://www.xxxmain.com/bookz.shtml .Xray include pretty good book with their cars. Team Orion propably has the best guide at http://www.teamorion.com/faq/car-handling.asp . While you're there check out Oscar Jansens motor tuning guide. also look at http://rctech.net/forum/showthread.php?t=40753
andsetinn is offline   Reply With Quote
Old 06-06-2005, 03:05 AM   #3
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Setinns basically got you covered but you could have a look at this site.
http://www.actionrc.com.au/Section_1.htm
It goes through everything about TC's even shocks and springs.
Sean
Team Duratrax is offline   Reply With Quote
Old 06-07-2005, 08:07 AM   #4
http://users.pandora.be/elvo/
Galifrey is offline   Reply With Quote
Old 06-09-2005, 04:05 AM   #5
thanks for the replys guys
some good reading there
Old 06-09-2005, 11:46 AM   #6
More homework for you!
http://ebiz.netopia.com/competitionx...ationdatabase/
http://home.tiscali.be/be067749/58/
http://rcxotic.com/contentid-2.html While you're there check out the Mask Depot
Old 06-09-2005, 12:10 PM   #7
teamgp's Avatar
I highly suggest the XXX Main book for basic help in pointing you in the right direction to solve a problem, but understanding how everything works together will take some time.
Its all about mechanical grip. BTW, just in case you didn't know "mechanical grip" means grip that is derived from the rolling chassis dynamics (weight transfer which is set using things such as weight distribution, spring rate, dampening, camber, caster, etc.), as opposed to grip gained from the tires or aerodynamics.
The Hudy setup book is a good read:
http://www.hudy.net/xhudy/showfile.p...252739b1ad8c24
I gained a better understanding reading these two books as well:
1. Engineer to win by Carroll Smith (formula one ideas) - You won't use half the book as it deals with real car parts we don't have in TC (brakes, etc.) & materials, but the second half is great for setup.
2. Chassis Engineering by Herb Adams (NASCAR/TRANSAM ideas) - The entire book is great, including a section on how to design a base setup from scratch and how to design your own chassis.
teamgp is offline   Reply With Quote
need suspension help! MAFIOSO8 Rookie Zone 3 07-20-2006 03:14 PM
WTB: 415 LW Suspension Kit g12314 R/C Items: Wanted to Buy 2 09-13-2005 10:50 AM
WTB: C-Hub Suspension iamjeff6 R/C Items: Wanted to Buy 1 12-01-2004 06:58 AM
Tamiya lightweight suspension - trade for 415 suspension letitroll R/C Items: For Sale/Trade 3 10-19-2004 10:45 PM
M-03 Suspension vala Electric On-Road 2 07-10-2004 10:43 AM
