Old 06-03-2005, 05:21 PM   #1
moot's Avatar
Default very old novak speedy help
hey guys. i have this old novak speed controller that still works that i want to put in an old mini. it works ok but just doesnt seem to have any punch.there is 2 screwdriver adjustments on it but i have no idea what there for or how to adjust it.
any ideas?
moot is offline   Reply With Quote
Old 06-03-2005, 05:58 PM   #2
rc_bam226's Avatar
any ideas?
I think its a T1 or T4 speedo. Here's a link to the manual in PDF format on Team Novak website: T1 & T4
Hope this helps.
rc_bam226 is offline   Reply With Quote
Old 06-03-2005, 06:05 PM   #3
Talking From an old Novak manual....
Plug controller into battery pack and leave motor unplugged.....
Neutral pot is on the left and speed adjustment is on the right (make sure they are both in the full clockwise position).
Turn on transmitter and speed control.
Slowly rotate the the neutral pot counter clockwise. The led will decrease in brightness to full off and then switch to full on. This is the neutral position.
Advancing transmitter throttle will make the LED go off and stay off. If the led goes of then slowly gets brighter, flip the transmitter throttle reversing switch and redo.
With the transmitter at full speed, slowly rotate the high speed pot counter clockwise on the speed control until the led switches on again. This is full speed.
Slowly release the throttle. The led should go off at about 85% full throttle.
Instructions came from the T1X but should work. Depends on the transmitter you have though. The manual shows that for most models back when it came out that throttle trim and high point adjustments should be set to max and throttle exponential to minimum. Brake exponential to minimum.
Mabuchi540 is offline   Reply With Quote
Old 06-03-2005, 06:06 PM   #4
Default I'd say a T4....
Hope this helps.
mine only had one row of fets. The instructions were pretty much the same as for the T1X which had two rows.
Old 06-03-2005, 07:16 PM   #5
moot's Avatar
thanks for the hep guys
the only thing is that it doesnt have an led.but i think i can work it out
Old 06-04-2005, 04:02 AM   #6
Simon K's Avatar
No LED might make it a Novak NESC4 or NESC1...I think one pot is neutral and the other *may* be power curve.
I had a NESC4 but can't remember which is which...too long ago
Simon K is offline   Reply With Quote
Old 06-04-2005, 04:39 AM   #7
Scrubb's Avatar
One pot is Neutral and one pot is full speed, first adjust the neutral pot just under the point where your tires roll forward (no reverse, just brakes), then with a voltmeter connected to the motor leads, adjust the full speed pot so that the voltage peaks just before you reach on full throttle on the radio trigger. this is a low frequency speed control, do not use a schotty diode, instead use a 47uF, 25volt electrolytic capacitor.
Scrubb is offline   Reply With Quote
Old 06-04-2005, 07:00 PM   #8
PMK
Yes what Scrubb said. If it doesn't set up I may have a set of instructions, but it will take some looking.
BTW, be careful as I don't know if it will handle any low turn modern motors. And unless running a srock motor it should use heatsinks that press onto the power and brake MOSFET's. Brakes are 2 that are offset and never short the brake and power MOSFET's.
Also as the battery is depleted, the steering will lock and the car will continue rolling with no control.
PK
PMK is offline   Reply With Quote
Old 06-05-2005, 03:24 AM   #9
Simon K's Avatar
I used a KO Pulse checker(i think it was called) to set mine up...basically worked the same as a setup LED does now and you just clipped it onto the motor leads.
I may still have it lying around.
Old 06-05-2005, 02:12 PM   #10
Thumbs up SNAP!!!
Dude same here. Mine was from a Ko CX1 esc. My pulse checker is still here too.
Novak GTX Speedy GSM Storm Australia For Sale/Trade 4 06-18-2008 03:04 AM
novak SS speedy {VIC_RDX} Australia Wanted to Buy 0 08-27-2007 12:21 AM
Novak SS speedy yeahyeah Electric On-Road 2 06-08-2007 08:55 AM
NOVAK GTX SPEEDY chookgb Australia For Sale/Trade 2 12-17-2006 12:27 AM
Novak GTX speedy HQH Australia For Sale/Trade 2 08-30-2006 12:52 AM
