Old 06-02-2014, 07:47 PM   #16
JimmyMac's Avatar
I just bought a shorter antenna. 100mm.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-03-2014, 04:38 AM   #17
Skiddins's Avatar
Fold the cable up and Shoe Goo to the side of the receiver case.
This one was Soe Goo'd onto the chassis, but my TC has it attached to the side of the receiver itself.
No interference at all in over a year of running it like this, including at large tracks used for 1/5 scale and 1/8 nitro etc.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-04-2014, 07:40 PM   #18
Send a message via AIM to JimmyMack12
Originally Posted by Carnage9270 View Post
The total length of the wire is the antenna, not just the exposed tip. Has to do with the frequencies traveling down the wire being tuned to a specific length. I'll see if I can find a decent article on it.
Edit: Here ya go
http://www.rc-cam.com/ant_exp.htm
Long story short, antenna length directly affects wavelength. You may not notice it so much if your receiver can pick up a signal at 100ft and you're only driving 50ft away. But going farther away you'll notice the signal drop off really fast and lose control.
Which was exactly what I had said a year ago:
Posted 6/30/13:
The length of the antenna is determined by what frequency range it needs. Longer antenna - lower frequencies (you'll see longer antennae with your older-style AM/FM radios with crystals). Shorter antenna - higher frequencies (2.4gHz).
JimmyMack12 is offline   Reply With Quote
Old 06-04-2014, 07:47 PM   #19
EDWARD2003's Avatar
Wind the antenna in a loop and zip-tie it. Boom!
EDWARD2003 is offline   Reply With Quote
Old 06-12-2014, 12:01 PM   #20
snuvet75's Avatar
Trader Rating: 16 (94%+)
I'm just surprised that lots of you are willing to mess with the antenna that much. Why don't you just hide it and fold it nicely and save the hassle?
I picked up a trick to bend the antenna tube so it doesn't stick out of the car body. Then the hell broke up due to the glitch. I broke my 977, 747 and Eryx all of them. Since then, I don't mess with the antenna and keep it nice and straight in the tube. Why take your unnecessary time when you have an option to just keep it as it is?
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is offline   Reply With Quote
Old 06-12-2014, 03:07 PM   #21
Skiddins's Avatar
I put mine beside the receiver as it sticks through the top deck and kept getting in the way.
I never get glitching
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 06-13-2014, 01:25 AM   #22
I just opened the receiver and put the antenna in there. Now, there are only about 5cm of it that are visible.
Never had problems in a year of use. Clean solution, which also keeps any sort of warranty.
Awesoman is offline   Reply With Quote
Old 06-13-2014, 04:19 AM   #23
M7H
M7H's Avatar
Edit: Here ya go
The link you referred to, was still in the 27 and 40 MHz period.
27MHz, is a wavelength of 11 Meter
40MHz, is a wavelength of 7.5 Meter
2.4GHz, is a wavelength of 0.125 Meter.
For best results it is technically allowed to have an antenne of 1/4 of the wave length, which gives us with our 2.4GHz stuff an antenne of 3.125 cm
And excuse me, but the actual antenne is only the exposed tip, the rest is coaxial cable!
So yes, technically seen, it is not a problem to cut the cable, as long as you leave the last 3.125 cm core of the coaxial cable blank!
I do suggest to mount the actual antenne (this 3 cm) as vertical as possible, because when mounted flat, it becomes direction sensitive, the receiver will see the worst signal, when the antenne points in a straight line to or from the transmitter. If this happens on a far corner on a bigger outdoor track, you will loose control.
Serpent
M7H is offline   Reply With Quote
Old 06-13-2014, 05:20 AM   #24
Skiddins's Avatar
I think what you mean is; 'If running Spektrum equipment you may well face glitching, no matter how small the track'
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 06-13-2014, 05:42 AM   #25
M7H
M7H's Avatar
Especially when there are Sanwa's and Futaba's nearby....
Serpent
Old 06-13-2014, 08:40 AM   #26
G-rem's Avatar
RX471 receiver? Or other?
I'd like to give it a try because my antenna is about 20cm^^ (still under the body)
G-rem is offline   Reply With Quote
Old 06-13-2014, 09:46 AM   #27
Hi G-Rem,
it was an RX451 receiver, not sure if it also works with a 471
Old 06-13-2014, 10:15 AM   #28
G-rem's Avatar
Thanks, I'll maybe try so
Old 09-08-2015, 12:48 PM   #29
I have a problem my antenna tip got stuck in my antenna tube and broke the white inner part off please help its a 472 i loose my signal at 50 ft? Can someone help me repair this rx.
cbrking805 is offline   Reply With Quote
Old 09-08-2015, 02:35 PM   #30
Roelof's Avatar
Send a message via ICQ to Roelof
Strip the shield until the inner wire sticks out 31mm
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
