Tweak stations
Tweak stations
Hi all
Does anyone still use the bubble, tee shape type tweak stations, and how?
Yup I have an Integy with the bubble and a laser,it works great. First you set it to the cars wheelbase. Then center both the front and rear using the markings to determine each ends trackwidth. Then adjust to get both ends level. When adjusting the shocks work with the shock on the opposite end and corner. An example is if the right front is off adjust using the left rear shock adjuster. If you only have the bubble level up the rear of the station before getting started.
