Old 06-02-2005, 03:54 AM   #16
asw7576's Avatar
Berger : you get around 3900-4000mah..... ?? What amp do you charge it ?
I'm using LRP Pulsar Competition charger with linear mode, 35mV delta peak, 4.5A charge rate.
My GP3300 max out around 3000 - 3100 mah
My IB3600 max out around 3300 mah
Old 06-02-2005, 07:02 AM   #17
PaZ
PaZ's Avatar
im gettin 3800,3900 outta my GP3300's chargin at 5.5amp thats in 6 cell and about 3600,3700 from the 4 cell, they are trayed before i charge em i thought that was normal
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 06-02-2005, 08:41 AM   #18
lonepalm4's Avatar
If you are getting nearly 4000 mah out of a gp 3300, then you probably were one of the lucky people who recieved the famous gp 3700's in 3300 shrink wrap. they sent quite a few of these out the door. a good gp 3300 should only get 3300-3500 mah worth of charge. Also, this # is not a true mah reading, because it will fluctuate with the ir of your cells. If the packs are in poor shape, they will appear to take lots of mah, but will dump quite quickly.
I've always found that just running the cells in race conditions is the best way to tell how they perform. especially with a brushless motor as you can eliminate the motor from the equation..
lonepalm4 is offline   Reply With Quote
Old 06-02-2005, 10:16 AM   #19
berger's Avatar
R/C Tech Charter Subscriber
Ive been charging between 6-10A...... and the mah values are almost the same as what i use with step charging, my advantage and pulsar comp1 give fairly similar figures......
Im not believing that they are 3700s in 3300 wrap as they would be larger cells so it would be obvious, that and a friend with 3700s puts 4300+ into them easily... My IR should be low as ive been using the spintec device and then traying them on the smart tray so i would say they are in good condition.....
berger is offline   Reply With Quote
Old 06-02-2005, 10:45 AM   #20
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
All of my 3300s charge over 3700+. I use LRP chargers set at 6amps and 30mv. I also discharge them on the new integy 30amp tray before I charge them. This makes a big difference. Even my year old used every week practice packs still take over 3700mah.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 06-02-2005, 11:21 AM   #21
tandman's Avatar
Send a message via Yahoo to tandman
I have used the IB3300's for a couple of months now. I bought cells in bulk and a friend matched them with his turbo 35....one cell at a time. Cycled each cell 3 times at a 35 amp discharge. Had 2 dead cells out of the 90 and 2 more very week cells. The other cells are awesome and out perform any other 3300 cells that I have tried. We grouped the cells together by voltage and I have a couple 1.170-1.172 packs with 360-370 runtime and a few more 1.164-1.167 packs with about the same runtime....all at 35 amp discharge. The packs perform best at 7 amp charge and have loads of punch in stock and enough runtime in mod touring with 10x1 DC V2's. Too much work though matching cells...so I will run the SMC 3600 packs in the future.
Thanks....Dwayne
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
INTELLECT WC 4200 2.40+ FiremanKen R/C Items: For Sale/Trade 10 03-25-2007 09:30 PM
ORION 3300 & PROMATCH 3300 4-SALE RED-LINE M03 R/C Items: For Sale/Trade 8 04-23-2006 03:44 PM
Intellect sub c miniczar R/C Items: For Sale/Trade 1 03-20-2006 11:42 PM
My test results: Intellect IB 3600 versus GP 3300 Cells Bob Nilsen Electric On-Road 30 04-01-2005 08:08 AM
GP 3300 and Sanyo RC 3300 HV Cells... RC RaceCars R/C Items: For Sale/Trade 0 01-28-2003 02:07 PM
