Turnigy TD10 1/10 Belt-Driven 4WD Touring Car >
Old 07-04-2013, 07:26 AM
  #16
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
TQRC in California carry all Sakura & 3 Racing kits & bits as well
http://www.tqrcracing.com/shop/produ....asp?p_id=6163
RedBullFiXX is offline
Old 07-04-2013, 08:33 AM
  #17
Hi guys,
Am thinking of getting one, just wanna know if the ESC and motor from HK good enough for racing(the so called 'blinky' class)? If it's good enough what would you suggest(maybe a link please). I'm really new to on-road(just a few months with off-road), so please advice guys.
Thanks a lot for any help i can get.
basher88 is offline
Old 07-04-2013, 08:46 AM
  #18
SteveM's Avatar
Trader Rating: 165 (100%+)
Originally Posted by basher88
Hi guys,
The TD10 (3Racing Zero S) is a good base for blinky racing and I prefer the Hobbywing Justock ESC over anything else. This ESC is reasonable priced and rock solid.
SteveM is offline
Old 07-04-2013, 09:38 AM
  #19
SteveM, thanks a lot for the advice, will take a look at the Justock ESC, cheers
basher88 is offline
Old 11-03-2013, 12:24 PM
  #20
GP40X's Avatar
Looks like the TD10s are back in stock.
I have a Sakura Zero version 2 Vertical mount and a pair of 96 tooth sour gears for sale. These also fit the TD10.
Sakura Zero S Turnigy TD10 parts
With the vertical mount you can go as high a a 51 tooth pinion with the 96 tooth spur gear.
GP40X is offline
Old 02-20-2015, 09:00 AM
  #21
Default turnigy td10
I'm having a hard time getting three e ring on the shaft i need help badly
rcknight23 is offline
Old 02-20-2015, 09:10 AM
  #22
SteveM's Avatar
What part of the build is this?
SteveM is offline
Old 04-09-2015, 02:19 AM
  #23
I did a build and review. Pretty impressed with the car as a budget runner
http://www.thercracer.com/2015/04/ho...nd-review.html
Qatmix is offline
Old 04-09-2015, 04:07 AM
  #24
howardcano's Avatar
Trader Rating: 37 (100%+)
That's a very thorough and professional-looking review!
howardcano is offline
Old 04-09-2015, 04:40 AM
  #25
SteveM's Avatar
I also did a build review long ago
http://rcottawa.com/2012/01/3racing-...zero-s-review/
SteveM is offline
Old 06-14-2015, 08:00 PM
  #26
hey steve, what pinion size were you running? were you also using the stock 80t spur gear?
legacygt777 is offline
Old 07-24-2015, 12:08 PM
  #27
Hi ya'll. I'm in the middle of my TD10 build, did the diffs and installed the belts and spur. I'm a little concerned about my spur, I have very small amount of side to side play..and I do have the little .02mm thick spacers installed. Is this normal, or am I doing someting wrong? Also, I'm going to run this car with a brushed setup. probably a 27 turn motor, or maybe an old "hot stock" 23 turn, and 6 cells. Any idea where to start with a pinion for this setup? Any help appreciated.
Cash
cashrc is offline
