Old 06-21-2013, 07:33 PM   #1
Trader Rating: 38 (100%+)
Default Chassis film install question
Got some JConcepts chassis film to throw on my TC6.1 so I can run the asphalt track (maybe). My question is what is the best way to cut out all the screw holes? From the looks of it, it's going to be a total PITA.
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
Old 06-21-2013, 08:01 PM   #2
mschumi101's Avatar
Trader Rating: 22 (100%+)
I just installed it on my TC5s. I didn't cut out any screw holes though. I just made sure they were all tight and layed it on making sure there were no air bubbles. Then I cut around the chassis edges and any vent holes in the chassis with a hobby knife. I don't see a need to access the screws on a normal basis, so I don't think you need to cut it. Screw holes may also provide a lip to be grabbed by something on the track. I would just cut them out when you need to. Then just use a hobby knife around the screw. But the chassis protector does a great job protecting the car on asphalt tracks.
Xray T4'17 USGT (coming soon) | Xray T4 ORCA 17.5
Orange Powered!
Previous: B5M | B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 06-21-2013, 08:27 PM   #3
Monteman's Avatar
Trader Rating: 16 (100%+)
Yeah i didn't open up any of my screw holes either. Figured that was something i should have done prior to building the car, but i built and finished the car before the film arrived.. I'm in the same boat, i shouldn't need to remove any for quite some time.
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 06-21-2013, 09:36 PM   #4
vabroom's Avatar
If the chassis is built already, you can use trace the screws with a hobby knife. Just do the holes that you need to make to make adjustments. The bulkhead holes only when you need to replace them.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 06-21-2013, 10:41 PM   #5
Thanks guys, I wanted to just cover all the holes but didn't want to screw (hehe) myself in the future...
Old 06-22-2013, 03:36 AM   #6
josecarlo1129's Avatar
Good day.
To the TS, I suggest you punch all the screw-holes accordingly or else it'll create a bubble after installing screws on it. I used a one-whole puncher. Photo attached for reference.
I do this all the time. HTH. Cheers.
JC
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 06-22-2013, 12:12 PM   #7
vabroom's Avatar
Is the JConcepts chassis film thin enough for TC?
Old 06-22-2013, 06:44 PM   #8
JC
cool, how do I go about making a template to punch the holes?
umm, thin enough for what?
Old 06-22-2013, 10:52 PM   #9
^ I scanned the chassis (making it as 1:1), printed the outline on a the clear film protector then punched every whole allotted for the screws.
Tip: Just provide a 'slit' to reach the middle holes since no way the puncher could reach that.
Hope this helps! Cheers!
JC
Old 06-22-2013, 11:28 PM   #10
vabroom's Avatar
For Touring Car chassis, the ones for off road are pretty thick
Old 06-23-2013, 01:33 AM   #11
Be aware that using thick films might affect the handling/flexing.
Old 06-23-2013, 01:52 AM   #12
vabroom's Avatar
So back to my original question, are the JConcepts thin enough for tc chassis?
Old 06-23-2013, 09:51 AM   #13
I'd like to know as well. Who makes a thinner sheet, when I searched all that came up was the JConcepts stuff.
Old 06-23-2013, 10:25 AM   #14
mschumi101's Avatar
I'm pretty sure the one I used is Jconcepts... I picked it up at the LHS. It came in a pack of 2 if that helps. I think it is thin enough... Its thick enough to hold up well to scrapes, and It hasn't changed the performance of the car (flex). I can add a picture later from the side... It's maybe .25mm
Orange Powered!
-Ted
Old 06-23-2013, 11:21 AM   #15
vabroom's Avatar
Thank you, that's the answer I was looking for.
