Old 06-21-2013, 05:40 PM   #1
jsr555's Avatar
Trader Rating: 17 (100%+)
Default Painting guru's -metallic paint
I was under the impression you normally back Metallic paint on bodies with silver. But I am using tamiya PS59 dark metallic blue and I wanted it a darkest blue as I can get it. So was going to back it in black....
Anyone see any issues?
Sorry, I have been advised by the thread police this post should be in the painting section. My bad. But hey, I was painting an electric on road car.
Xray T4 & HPI/HB Pro 5 - Powered by Hobbywing
SQ: HPI RS Pro -HPI RS Pro 2 - HPI Pro 3 - HPI Pro ?? - HPI Pro 5
jsr555 is offline   Reply With Quote
Old 06-21-2013, 06:32 PM   #2
chasingthepack's Avatar
no,go for it
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 06-21-2013, 06:53 PM   #3
Odin544's Avatar
Trader Rating: 93 (100%+)
you'd get more responses in the painting forum.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 06-21-2013, 07:04 PM   #4
jsr555's Avatar
Thanks, I've moved it. And my thread police comment was not directed at you, but my mate who let me have it ....😳
Old 06-21-2013, 07:43 PM   #5
I've had issues with Tamiya paints before, more specifically the metallic/flourescents and the backing black bleeding through them. I stopped using Tamiya for various reasons, that being one. Anyways, even after 4 coats of the color on one body I had the black backing bleed though.
Last time I used Tamiya paints I did 2 coats of the color, backed by one light coat of metallic silver to give it a little extra pop and then hit it with black with no bleed through.
Typically, if you use a dark color, you'll back it with black, if you use a lighter color, back it with plain silver white. Using metallic silver/silver flake between the color and backing helps give the color a little extra pop, or a lot if you do a heavy coat.
wareagle84 is offline   Reply With Quote
Old 06-21-2013, 08:18 PM   #6
Lessen's Avatar
Send a message via MSN to Lessen
Personally, I'd stick with silver. Backing with black just introduces risk of bleed. If you're set on trying black to darken the overall effect just take extra care to get a good even coverage of your metallic layer. I'd say four light coats... gotta be light.
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 06-21-2013, 09:01 PM   #7
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
just use a darker silver to back if you wanna go darker. a pearlized black would also work.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 06-21-2013, 09:51 PM   #8
Odin544's Avatar
No worries. I only suggest there because thats where you will get advice from the guys who are painting every day. good luck with getting the results you want.
TriCitiesRC.com
Old 06-21-2013, 10:54 PM   #9
jsr555's Avatar
Thanks for the input. I'm actually trying to get a dark blue to do a 2012 Williams F1 and dark blue paints are hard to come by here...
Anyway, I have enough to think about now.
Thanks.
