Old 05-31-2005, 06:06 AM   #1
acutts's Avatar
Default Braking Problem (Twister2 and Helios)
Hi
I have just started using a twister 2 with my helios and yesterday when running my T1FK05 for first time it seemed like I had no brakes. I had the abs setting on my radio switched on with settings 98 , 5, 33 but no braking at all. I am running the locked front spool.
I am wondering if there is a setting on my speedo twistr2 that I need to set or could there be a setting on my helios that is not working?
Hope someone can help
Scott
acutts is offline   Reply With Quote
Old 05-31-2005, 06:18 AM   #2
brandbrainz's Avatar
Hi
try to do the start setup on the Twister with ABS OFF. That should help.
brandbrainz is offline   Reply With Quote
Old 05-31-2005, 06:30 AM   #3
Crashmaster's Avatar
Acutts,
Did you attach the supplied diode to the motor. I forgot to with my VFS-2000, and it blew the brakes.
Crashmaster
Crashmaster is offline   Reply With Quote
Old 05-31-2005, 06:56 AM   #4
acutts's Avatar
Originally Posted by Crashmaster
Acutts,
Crashmaster
Oh dear
When I set car up I had a motor with that supplied diode in then I switched and connected another that had a std diode and I switched car on it smoked the diode immediately so I turned off and changed motor....! Could this be the end of the speedo .....??? I will be well pissed if it is ... the car ran fine except that the brake function didn't seem to work but I am not very sure of settings so how can I tell.
Old 05-31-2005, 07:16 AM   #5
I found the speedo just had no brakes what so ever when I blew the power board. The only thing causing it to slow was tranny drag/ motor braking. If they have gone, u can get it fixed from your local centre, its what i did (cost around 50).
Crashmaster
Old 05-31-2005, 07:30 AM   #6
acutts's Avatar
Crashmaster
Bleak
What a muppet I am ... I will try reset tonight if that doesn't work I will send it in .... does it take long?
Old 05-31-2005, 08:59 AM   #7
Hi,
I've send in one off my ESCs and they repaired it within 3 weeks. Pretty fast if you ask me. But try to set it up new. Best thing for test is to switch your Helios to a different model memory.
Old 05-31-2005, 09:03 AM   #8
It didn't take mine long for the repair. I sent mine to helger (uk importer for KO), but I'm not sure where you would send yours as it is imported by mirage, but is still a KO at heart.
Cheers
Crashmaster
Old 05-31-2005, 09:23 AM   #9
The Ko guys do repair all off the VFS-1 (Corally, tamiya,rayspeed...)
Old 05-31-2005, 10:27 AM   #10
acutts's Avatar
I am sitting with the car on the race table now and it is very difficult to see if the brake is working or not. I am worried it could just be a setting on the radio. Does anyone know what setting should be used on the ABS function on the helios?
Width 33
Pos B 5
Cycle 98
Delay 0
Duty - || +
Those are my settings ???
Thanks I guess if I can't see the difference between braking and letting the car motor brake then the brakes prob are not working???
Old 05-31-2005, 11:56 AM   #11
Normally you will see the difference between braking and motor bracking. If you brake the motor should stopp at once. Motorbracking will keep the wheels turning for a little while. Try to switch to another model on the helios then set up the speedo again. The new model memory will not have abs
HPI sprint 2 braking problem Rufus2000 Electric On-Road 8 09-08-2009 03:20 AM
Problem with Mamba braking or something? Paul Whalen Electric Off-Road 19 02-08-2008 06:21 AM
Helios Problem Glowster21 Electric On-Road 19 07-26-2006 04:51 PM
HB cyclone, Pro-Trak,Twister2.1,Helios...4sale!!! redd R/C Items: For Sale/Trade 2 07-12-2006 11:02 AM
ko helios problem sedanaddict Nitro On-Road 6 04-11-2005 06:39 PM
