Old 05-31-2005, 01:10 PM   #31
OSherman's Avatar
hardware??
one or some of the screws may not be flush with the bottom of the chassis.
i usually check this type of tweak with a drafters triangle or steel rule. i will check front to rear (down the center, a lil to the left and a lil to the right). i also check left-to-right (somewhere at the front of the chassis, in the middle of the chassis and at the rear of the chassis).
just hold the 'straight edge' on the bottom of the chassis, any gaps between the 'straight edge' and the chassis indicates a tweak.
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 05-31-2005, 01:18 PM   #32
yes i can slide a dime under the edge of it, and when i press i can a penny also
James605 is offline   Reply With Quote
Old 05-31-2005, 10:07 PM   #33
How do you post pictures?
donny is offline   Reply With Quote
Old 06-01-2005, 04:41 AM   #34
tc3blue's Avatar
OK, two questions:
1. was the chassis (bottom plate tweaked when you took it off?
2. did you remove all the droop screws??
(I'm asking this because someone at my track had the same problem, a long time ago with his tc3 and his problem was fixed by removing droop screws and then properly setting it up)
so make sure all the 8 screws are removed
tc3blue is offline   Reply With Quote
Old 06-01-2005, 04:58 AM   #35
Doughty's Avatar
from reading all your posts am I right in thinking that when the car is sitting on the table without you touching it only 3 wheels are in contact with the ground?
- as said before, take all 8 droop and bump stop screws out of the wishbones (completely out just to be safe)
- take all your shocks off the car and check they are all equal length (or at least equal left/right on the front and the back)
- check the wishbones move up and down freely
- look down the underside of your chassis, if you have got the amount of tweek you are saying and you chassis is to blame then you would clearly see a twist down the length of the chassis
If that does not help, pictures of us to 'see' your problem would make our job easier.
Chris Doughty - Team Durango - LRP - BETA Tires - Nibbo Design
Doughty is offline   Reply With Quote
Old 06-01-2005, 05:39 AM   #36
Some of you don't get it.He is checking it without the wheels on the car.
I know this because mine does the same thing.Not as severe 2-2.5mm.
I contacted Losi,they said they would look at the car if I send it in.
I can't be without my car for this weekend (series race) so I ordered new
chassis,top plates,bulkheads.I will find the problem and send in the bad parts
for a refund.
JRXSBMAN is offline   Reply With Quote
Old 06-01-2005, 02:53 PM   #37
TLRacing
Todd Hodge's Avatar
Originally Posted by James605
Has anyone ever had to deal with sending a kit back to losi? How is their service? Just wondering because i think thats what I am going to have to do.
If you want to send it back in please do so. I will personally check it out. If there is something wrong we will get it fixed for you.
Please send to
Team Losi
Attn: Todd Hodge
4710 E. Guasti Rd
Ontario, CA 91761
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 06-01-2005, 04:07 PM   #38
tc3blue's Avatar
for a refund.
It doesn't matter if he's checking it with the wheels on the car or not. He should defiinitely do what I said and what Doughty and others said before sending it in. Especially the droop screws...
Team Losi JRSX Type R + Body (NEVER BEEN RUN) crankerUP R/C Items: For Sale/Trade 5 08-20-2008 09:13 AM
LOSI JRSX-R - Like New TeamB&B R/C Items: For Sale/Trade 1 01-05-2008 11:22 AM
WTT:LOSI BUGGY AND JRSX-S TYPE R FOR MICRO magilla66 Other Items: For Sale/Trade or Wanted to Buy 0 12-30-2007 12:22 AM
Tweaked Racing ECD-R Clodbuster dway100 R/C Items: For Sale/Trade 0 03-27-2005 11:22 AM
Fantom Limited Edition 'Tweaked' Monsters? hawker Electric On-Road 27 11-02-2003 07:27 PM
