Old 06-08-2013, 04:51 PM   #1
TheStnchOfSpeed's Avatar
Default Can using very light braking burn up a ESC?
I have a top speed car that keeps burning up speed controls. It is of course geared very tall, but has the power, etc, to turn the gear. I keep burning ESC's up on 8s even without putting ANY heat in the thing. My set up is 2 wheel drive and because of this I have to turn the breaks WAY down.....like 20%, or the back tires slide. Could the combination of tall gearing and very slight braking be contributing to this problem?
TheStnchOfSpeed is offline   Reply With Quote
Old 06-08-2013, 09:13 PM   #2
Galeleo's Avatar
What speed controller are you using? Is it rated for 8S?
By the sounds of it, with the limited information provided, you are running too much voltage through the speed controller.
If the speed controller can handle 8s, then I would check all your solder joints, especially on the motor end bell. You may have to take off the end bell where the solder tabs are and check that there isn't a short between the tabs on the motor. Sometimes if too much solder is used when soldering the wires to the motor, the extra solder will form a bridge between tabs or to the motor can.
Also check the solder joints on the speed controller. Make sure there are no short circuits.
If you are using a castle system, then once again, check all connectors and inspect the motor can.
Hopefully this helps, or gives you a starting point to solve the issue.
Galeleo is offline   Reply With Quote
Old 06-08-2013, 09:33 PM   #3
more info ; motor . speedo used FDR ... you might just be running too tall . even if it does have power to pull the gearing ... what car/truck are you running ...
Mark Barden .
mb racer is offline   Reply With Quote
Old 06-09-2013, 06:54 PM   #4
I'm currently using the Trackstar 1/5 scale ESC.
Old 06-09-2013, 08:22 PM   #5
I dont think its a ESC problem .. might check out the drive train of your car ,, sound llike you have something binding maybe bearings .. if there are bad ones they show up when there is some heat build up in them and when you check them cold they seem ok .. using light breaking i doubt will cause the problem your having .
Mark Barden .
Old 06-10-2013, 01:58 PM   #6
Bearings etc are all in good shape. As a matter of fact most of them are new.
Old 06-10-2013, 02:11 PM   #7
wingracer's Avatar
Trader Rating: 24 (100%+)
I know nothing about that speedo but according to this:
http://www.hobbyking.com/hobbyking/s...s_car_esc.html
It's only rated for up to 6s. I would say that is the problem.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-10-2013, 02:51 PM   #8
That's the wrong one. As I said, I'm using the 1/5 scale one. It's rated for 8s.
Old 06-10-2013, 02:54 PM   #9
Does anybody actually know what the capacitors are actually doing? I know what capacitors do but I wonder what they are used for in a speedo. There has to be a reason I am cooking the leads off of them.
Old 06-10-2013, 02:54 PM   #10
locked's Avatar
that's the 1/8th scale ESC. He said 1/5 scale, so I would assume this one.
http://www.hobbyking.com/hobbyking/s...o_Car_ESC.html
Speed runs don't do it for me, but if I was to build something for that purpose, I'd probably use an ESC rated for far more than I would plan to give it. Like something capable of doing 12s. Maybe an aircraft ESC.
locked is offline   Reply With Quote
Old 06-10-2013, 04:29 PM   #11
Trader Rating: 38 (100%+)
The capacitors keep the voltage levels down. With the high frequency switching, you could possibly see up to triple your actual voltage at the input of the speed control. Now to figure out if the issue is caused by the caps coming unsoldered or if the issue is the caps coming unsoldered. For your use, I'd suggest lead free solder as it has a higher melting point and I'm sure you are building a lot of heat. You could add extra caps as well.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 06-10-2013, 04:29 PM   #12
JayL's Avatar
It is probably your gearing, that is what usually, other than shorts, kills esc's
too small pinion esc hot
too big pinion motor hot
what are some of your motor and esc temps after a run?
MOD: A800X LRP FlowX X22 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 06-10-2013, 05:06 PM   #13
The most recent time this happened, it happened before I even made a run. ESC and motor were DEAD COLD. No temp whatsoever.
Old 06-10-2013, 05:09 PM   #14
The caps aren't coming unsoldered. The leads are literally melting in two. The cap itself looks perfect other than melted leads.
Old 06-10-2013, 05:45 PM   #15
Geezatec's Avatar
Function of capacitor. 1) Filter out AC Noise in AC circuits. 2) Acts like battery with DC circuits. RC's DC circuits act like a battery, with NiMd or lipo's jumping or fluctuating in voltage. It keeps the 6v it needs to operate servos and ESC.
Geezatec is offline   Reply With Quote
