Old 06-03-2013, 03:13 AM   #1
Default Tekin Blinky RS Pro
Not sure if covered before, just got back into racing starting Blinky 17.5
Speed flat loaded up new software and put in locked mode
Can you tell me which lights flash on speedo, and settings on dash board
Dain
Dain is offline   Reply With Quote
Old 06-03-2013, 05:44 AM   #2
STLNLST's Avatar
Trader Rating: 21 (100%+)
There should be three lights flashing when in "Blinky" mode. As far as the dashboard it will show you the settings selected from your brake and throttle settings. You'll have to run the car and see what feels right to you. The Tekin website has set up's posted that can point you in right direction. If there's not a set up for 238 yet use one from 223. They all transfer over.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-03-2013, 06:36 AM   #3
I haven't used my RS in a while, how is the 238 software?
I'm not sure exactly what number lights flash but its 2,3,4 I think and all at full throttle/brake. While in blnky those 3 lights flash and every 3-4 flashes number 1 will blink alone, at least on mine it did
JOE SI is offline   Reply With Quote
Old 06-03-2013, 12:28 PM   #4
Skitee's Avatar
LED's 2,3 will flash in blinky mode
LED's 2,3,4 will flash in locked spec mode, this is the mode a lot of events want you to run.
The alternate flash between the "blinky" flashes is the onboard temp indicator.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 06-03-2013, 12:41 PM   #5
EricW's Avatar
It's actually lights 3,5 for blinky and 3,4,5 for spec lock blinky.
http://www.teamtekin.com/rs_troubleshoot.html
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 06-03-2013, 12:54 PM   #6
Skitee's Avatar
thanks...
Old 06-03-2013, 08:04 PM   #7
STLNLST's Avatar
238 will be for the new RS Gen2 speedo. 223 is the last update for the older RS and RS Pro units. Which one do you have?
Old 06-03-2013, 09:06 PM   #8
Old RS, 223 already installed. I want to try the new Gen2 but went with an ORCA and I'm not going back to the RS but will try the GEN2 eventually
