My Traxxas Rally GT8 >
Old 05-31-2013, 07:19 PM
humayraykinaon's Avatar
Trader Rating: 4 (83%+)
Default My Traxxas Rally GT8
hello everyone, I have a traxxas rally 1/10 that I transform into an onroad car. My first intension was to get the XO-1 but my budget was a bit short so instead I got the rally roller off ebay and start woking my way to get it into what its now lol. I got the roller cause I already have electronics that I can drop in (MMM/2200) but before I put this combo in I wanna make sure my driveline can withstand all that power so, I pick up tekno M6 cvd along with XO-1 c-hubs/carriers, diffusers, XO-1 diffs, and 3 GT8 bodies (PF8, DP8 & DTM)
fresh roller
XO-1 c-hub/carriers and tekno M6
pro trac arms and XO-1 CVD repair kit #6757
hybrid CVD (XO-1 stub axles/tekno M6 dogbones
front installed with GTR shocks
rear
more.....
humayraykinaon is offline
Old 12-24-2013, 06:05 PM
XO-1 shock towers with homemade chassis brace
I use a solid aluminum tube that I bought from Lowes. cut it to length then, I drill holes at each end and let the screw make the threads then drill holes in the middle of the shock towers.
Old 12-24-2013, 06:10 PM
didn't like how the body flaps around so, I use some body post to support the sides and added front splitter.
piece of thin cutting board that I cut to shape
Old 12-24-2013, 06:32 PM
after I did all that ^^^ I'm thinking what if I use the XO-1 diffuser/splitters? so, order the XO diffuser/splitters, few days later showed up in my mailbox. so, start tinkering of how I can mount them on the Rally chassis. first, I cut the side diffuser and glued them.
front splitter turned upside down to make up with the angle of the bulkhead,this way it will stay straight with the chassis line
trim this part to free the arms
trim off this part of the arm to clear the diffuser
Old 12-24-2013, 06:37 PM
I have to trim the rear diffuser about this much to clear the arms
then trim this part
and this
doing so will get it closer to the chassis.^^^ but, even though I did all that I still have to put a piece of plastic to fill in the space
Old 12-25-2013, 10:24 AM
ThePanda's Avatar
Trader Rating: 68 (100%+)
wow very nice work, good way to be creative with parts!
ThePanda is offline
Old 12-25-2013, 12:08 PM
thanks ThePanda. I do more on tinkering than driving
here are the bodies that I swap around,
this is my latest body freshly painted,
previous ones
a different style body DP8
DTM
Old 04-04-2014, 09:15 PM
my latest body OFNA X3
I like it so much, I got a 2nd one lol
another PF8 also
Old 04-08-2014, 03:19 AM
FLoJo's Avatar
That ofna x3 looks great , where did ya get it
FLoJo is offline
Old 04-21-2014, 11:02 PM
Sorry for the late respond, you probably know where to get it by now lol, anyway I got it from nitrohouse.com
Old 04-21-2014, 11:25 PM
in order for me to fit this X3 body, I have to modify my rear shock tower to get it lower and shortened the suspension.
I cut it like so (ignore the top piece)
with a piece of plastic sheet, I cut my design mock up mount.
next to the actual mount (mount piece cut from my T-Maxx chassis)
finished...the part I said to "ignore the top piece" used it as brace
shortened suspension by putting those blue rubber damper inside
one done compared to without damper inside
here's before I did all that^^^^
the body fits but its touching the inside part which causes the paint to chip
Old 04-22-2014, 06:13 AM
FLoJo's Avatar
Seems like a lot of work just to fit one body ... So what if u wanna put another body n can u use existing mounts ? Or have to throw a differnt setup in there
FLoJo is offline
Old 04-22-2014, 07:14 AM
No, just longer body post and the bumper foam for shorter nose body.
Old 04-22-2014, 11:32 AM
ViperZ's Avatar
That's just the things some people are willing to do. Simpler than building a new chassis for a body, which many others do repeatedly
ViperZ is offline
Old 04-23-2014, 03:43 PM
Bought an HR LCG aluminum front bulkhead, this should give the front much stiffness/strength.
