New Novak Brusless System >
Old 08-22-2006, 04:10 PM
  #1336
STLNLST's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Marcos.J
mine is on its way too
What final drive ratio have you been using? I'm really liking 11.1
STLNLST is offline
Old 08-22-2006, 04:24 PM
  #1337
Trader Rating: 49 (100%+)
I see you guys talking about sintered rotor. what is that? When would you replace that and do I send it in to Novak to replace?
Yellowtaro is offline
Old 08-22-2006, 04:42 PM
  #1338
Super Moderator
Marcos.J's Avatar
Trader Rating: 213 (100%+)
Im at a 11.17 FDR on my Cyclone with the 4.5
Marcos.J is offline
  #1339
Nexus Racing's Avatar
It is a new optional part...you can add it yourself:
Novak Electronics Velociti Nickel-Plated Sintered Rotor
Nexus Racing is offline
Old 08-22-2006, 04:44 PM
  #1340
Super Moderator
Marcos.J's Avatar
Got one of the Nexus fans (30mm x 30mm) and it works great! flows alot more air than the stock fan!
Marcos.J is offline
Old 08-22-2006, 05:17 PM
  #1341
STLNLST's Avatar
Where can I get one of those fans from?
STLNLST is offline
Old 08-22-2006, 05:20 PM
  #1342
Wire it up for 7.2V and you will like it even more ! The output on the GTB fan plug is 6V.
I have all my fans wired to the ESC battery/power cap wires (7.2V) with a seperate switch and a "special" fan power distributor :
BTW, the fan is from MuchMore (just trying to make sure everyone realizes that we do not sell them with our own branding). We try to keep a good inventory of them.
Old 08-22-2006, 05:41 PM
  #1343
Charlie's Avatar
Hi Guys,
The new rotor should have more natural drag brake in the motor, so less is needed from the ESC setting. This helps reduce both motor and ESC temps.
Email me for some details on wiring up your fans for 7.2. There is a basic trick of changing just One Wire of the fan. It's actually shockingly simply. Just take the RED lead from your fan, and connect it to the BLACK lead on the Switch. This will provide the fans with 7.2 volts when the switch is turned on. No need for extra anytying that way. Just the simply moving of a wire.
Additionally, we've done a bit of testing with "multiple" power cap trans modules on the GTB and found that 2 in parrallel is good for reducing Cap temps quite a bit, and slightly reducing ESC temps.
I know, MORE caps, great right..... Its not necessary, but it does help. Any help is a good thing.
Charlie is offline
Old 08-22-2006, 05:42 PM
  #1344
AngryAsian's Avatar
How much life are you getting out of the fan, running it at 7.2V?
I've got a couple in the pixbox, ready for when the GTB fan dies.
But, mine is the larger model.. 30x30 which seems to be thinner.
Here's mine mounted:
AngryAsian is offline
Old 08-22-2006, 05:44 PM
  #1345
Super Moderator
Marcos.J's Avatar
Originally Posted by Charlie
Hi Guys,
thanks for the tip!
Marcos.J is offline
Old 08-22-2006, 05:50 PM
  #1346
The one on top of the ESC is the same fan I have been using for over a year at 7.2V!
Old 08-22-2006, 05:52 PM
  #1347
MuchMore 30x30mm Fan
  #1348
Super Moderator
Marcos.J's Avatar
where is your top-deck??
Marcos.J is offline
Old 08-22-2006, 06:00 PM
  #1349
AngryAsian's Avatar
Marcos.
The picture was taken whilst I was waiting for a new topdeck to arrive. I was going to put in some confusing quip about chassis flex and lower lap times......
Thanks for the tip Charlie - will definately try it..Red wire to black switch. Black wire to battery.
Is it okay to use the V4/V8 series of caps instead of two parallel novak caps?
Has anyone tried it?
Old 08-22-2006, 06:05 PM
  #1350
Super Moderator
Marcos.J's Avatar
Marcos.
lol you need to get a micro receiver on that Cyclone!
Marcos.J is offline
