Old 07-10-2006, 02:32 AM   #1246
Nexus Racing's Avatar
Originally Posted by johnbull
I haven't read all this thread but note that the main complaint with the brushless system seems to be a lack of brakes.
I am running a brushless 4.5 on 1 Yoke Bd, and a GTB (Brushless speedo) with Checkpoint 7 x 1 on the other. I also use a KO Vantage radio.
No matter what I do I can't get satisfactory brakes with the brushless. Run the GTB with a brushed motor and the brakes are fine. Run it brushless - no brakes worth talking about.
I don't want much drag brake - I don't like drag brake. I want straight forward mechanical brake when I pull the brake stick back. I can dial in as much drag brake as I like but that's not what I want.
Can anyone help with suggestions of speedo and radio settings. Thanks.
It does seem that, overall, the brakes on the BL are not capable (yet) of being as crisp as the brakes on a brushed mod. Here are two suggestions I have for adapting:
1. Going straight from the throttle to the brakes does not seem to work well. If you let the car coast just a split second before touching the brakes, it seems to slow much better!
2. It seems like I can slow the car down a lot more effectively if I use only partial brake (not sure why). I, myself, leave my brake travel at 100%, but I only partially hit the brakes with my finger, depending on how much braking I need at a particular corner.
Hope this helps!
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 07-10-2006, 07:09 AM   #1247
AdrianM's Avatar
The brake issue seems to be motor related. I have seen this in both Novak and LRP systems. One motor will have great brakes and another new motor of the exact same brand and wind will have very soft brakes. I have no idea why this is the case but I have seen it several times already.
Adrian Martinez
Old 07-10-2006, 07:16 AM   #1248
gizmo360's Avatar
yes it is to do with the magnets and the rotar in the motor
you also find as the race goes on and the motor/magnets get hotter the brakes get weaker ! . the cooler you keep it the less bad it gets ! and its not as bad also i guess on a smaller track as their is less speed to take off and less heat !
gizmo360 is offline   Reply With Quote
Old 07-10-2006, 06:02 PM   #1249
King-G's Avatar
Send a message via ICQ to King-G
The brakes on my Nosram - 4 star are incredible...First time I ran it and applied the brakes from full speed, all 4 wheels locked up into a skid!
I have had to dial my brakes down to 50%epa, and neg 100% curve...
King-G is offline   Reply With Quote
Old 07-11-2006, 05:39 PM   #1250
STLNLST's Avatar
Trader Rating: 21 (100%+)
I ran into the same problem as everyone else so I'm looking for answers as well.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-11-2006, 09:02 PM   #1251
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
I was having the same issue with the brakes after doing the one touch set up. I had my endpoint set at 100 so I just bumped it up a bit and, Voila!, I had wicked brakes. Lock the tires and skid type brakes...
RcCzarOfOld is offline   Reply With Quote
Old 07-11-2006, 10:28 PM   #1252
STLNLST's Avatar
If the radio is set up right 100% should be all you need right?
I'm going to install a heat sink and a fan on the motor and play with the settings for the next time out. I may try it for tis weekend or just wait until the next speedworld race. I'm not giving up that easy.
Old 07-12-2006, 04:58 AM   #1253
noline's Avatar
Has anyone tried a brushless system in there 1/12 th car I plan to run 4-cell Modified Roacourse But Im not sure which one to get I need something close to a 8 or 9 turn any help would be greatly appreciated
noline is offline   Reply With Quote
Old 07-12-2006, 07:27 AM   #1254
STLNLST's Avatar
Maybe the 5.5 or the 6.5. The 4.5 seems to be up there with the 7turns in a sedan so in a 12th scale I'm thinking 6.5 (maybe)
Old 07-12-2006, 08:51 AM   #1255
TMS
When I programed my 5.5 system at 100% endpoints, the brakes were really soft. I then re-programmed the throws at max endpoints and the brakes came on strong.
Some radios will max out well over 100% on the endpoints. The M8 goes to 140% throttle/160% brake. The instructions for the GTB ask for max endpoints.
hope this helps.
TMS is offline   Reply With Quote
Old 07-12-2006, 01:13 PM   #1256
STLNLST's Avatar
hope this helps.
I have always set everything to 100. I will have to see how high the KO goes. There are guys here ready to sell their brushless equipment and I'm hoping to find out something that works to keep them from doing that. From last weeks testing the GTB thermals at 160. My big question is what can you do against this when the track is about 150??? A 10 degree window isn't much. A couple of guys have cut their wires to keep it from going into shut down but I was told this is a no, no so I will leave mine they way it is and try other methods. I'm going with a fan, motor heat sink, and different settings for the next time out.
Old 07-12-2006, 01:48 PM   #1257
RobertV's Avatar
Track temp might be 150 but that doesn't have much to do with the temp your speedo is at the start of your run... unless you are leaving it sitting in the hot sun. Your "window" is considerably larger then 10 degrees.
Either way defeating the thermal circuit means you also take the risk of damaging your GTB if it overheats. Good luck man, that thing is stupid fast I hope you work out your issues.
RobertV is offline   Reply With Quote
Old 07-12-2006, 02:49 PM   #1258
If anyone is interested in another replacement fan for the GTB, here's the link to the fan I just installed. Air displacement is awesome.... should be cooling a lot better then the standard one.
Its a sunon GM0503PEV1-8.N.GN ; -> flow [email protected] 5V: 2.31l/s or 4.9cu.ft/min (Highest I ever saw on a fan this size)
http://be.farnell.com/jsp/endecaSear...=9606262&N=401
Quante is offline   Reply With Quote
Old 07-12-2006, 03:10 PM   #1259
HVAC25000's Avatar
Trader Rating: 19 (100%+)
Sounds great, now if only it were in America for us poor Americans...
HVAC25000 is offline   Reply With Quote
Old 07-12-2006, 04:01 PM   #1260
STLNLST's Avatar
I'm just curious to know how long you actually have before the speedp temp catches up with the track temp. You know how the weather gets out here. I will find out soon.
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
