New Novak Brusless System >
Old 07-05-2006, 09:06 PM
  #1231
Originally Posted by syndr0me
Here's some info from Novak's site:
Crawler 18.5 (w/Crawler ESC)
This price list mentions the 13.5, but the link goes to the page for the 4300. I wonder if the 4300 is being replaced?
Actually, here's the info page for the 13.5.
Now, before anybody gets their panties twisted, all this info was found by simply searching for a few keywords on Google.
Super sleuth over here. Nice finds.
Interesting that Novak says the 13.5 is compatible with both the GTB and SS+, but no mention of the regular SS ESC. It's kind of a downer since most people who bought the 4300 system, myself included, wanted to do so in order to even the playing field. However, if this is not the case, I have no problem selling my 4300 system to get a GTB and this 13.5 if it does indeed meet approval.
This could be the final chapter for brushed (at least stock) motors if it does pan out like I hope it does.
emjay is offline
Old 07-05-2006, 09:11 PM
  #1232
syndr0me's Avatar
Trader Rating: 32 (100%+)
I agree. It's another nail in the coffin of brushed motor racing. Good riddance.
syndr0me is offline
Old 07-06-2006, 03:51 AM
  #1233
gizmo360's Avatar
Default Brakes
with regards to the GTB AND THE 4.5 VERSION
i am sure this must have been talked about before ! but i think most people and myself are having BIG problems with them with regards to brakes !!
even on full brakes it just is no where near enough !!!
any ideas on how to sort this or does it need an update to the software to fix !
gizmo360 is offline
Old 07-06-2006, 04:38 AM
  #1234
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
i dont know how you guys are setting your GTB but mine has way too much brakes ,
Marcos.J is offline
Old 07-06-2006, 04:42 AM
  #1235
gizmo360's Avatar
is your one not the original one ? as they came out with to much brakes and all of the new ones do not have enough . i have just set them as standard and with max brakes.
gizmo360 is offline
Old 07-06-2006, 04:47 AM
  #1236
Super Moderator
Marcos.J's Avatar
mine is about 8 months old,
How are your radio settings?
Marcos.J is offline
Old 07-06-2006, 05:07 AM
  #1237
Drewdc90's Avatar
Mine brakes harder if I turn my brake EPA down to 80%.
Drewdc90 is offline
Old 07-06-2006, 08:14 AM
  #1238
I like the low brake setting, helps to stabilize the car with my driving style. I like to use a tiny amount of brake when entering a corner on low to medium grip surfaces, like asphalt
Jan Larsen is offline
Old 07-07-2006, 11:15 PM
  #1239
syndr0me's Avatar
Anybody know if the 4300 that comes in the Losi RTR truck can be purchased separately? It appears to have the newer style solder tabs like the Velociti motors. I wonder if Novak will update the existing 4300 and 5800 soon?
syndr0me is offline
Old 07-08-2006, 12:16 AM
  #1240
AFAIK it is only available with the Losi RTR. Asides from the solder tabs, it also has black plastic endbells.
emjay is offline
Old 07-08-2006, 01:37 AM
  #1241
The Evicerator
In regards to the brakes being different on new to old units:
There have been NO hardware or software changes that will affect the braking performance of the GTB since it has been brought into production.
Steve Weiss is offline
Old 07-08-2006, 05:14 AM
  #1242
gizmo360's Avatar
then why are we suffering with poor brakes then ! compare to the GTX the GTB has much softer brakes ! and on a big track is hard to stop , but is perfect with the GTX ?? any ideas what we are doing wrong
other have said the same thing............
gizmo360 is offline
Old 07-08-2006, 06:04 AM
  #1243
Super Moderator
Marcos.J's Avatar
improper settings on your radio and esc?? I have plenty of brakes on mine and my other frien has one with no probllems at all, check your radio settings and your esc.
Marcos.J is offline
Old 07-08-2006, 09:08 AM
  #1244
STLNLST's Avatar
I get to run mine for the first time today. I'll make sure that my radio settings are set correctly and I'll report back on how my day went. It's going to be a hot one today so I hope my gearing is correct and it doesn't thermal. Starting at 10.2. I want to go 10.5 but I can't get the gear mesh with a smaller pinion
STLNLST is offline
Old 07-10-2006, 01:11 AM
  #1245
johnbull's Avatar
I haven't read all this thread but note that the main complaint with the brushless system seems to be a lack of brakes.
I am running a brushless 4.5 on 1 Yoke Bd, and a GTB (Brushless speedo) with Checkpoint 7 x 1 on the other. I also use a KO Vantage radio.
No matter what I do I can't get satisfactory brakes with the brushless. Run the GTB with a brushed motor and the brakes are fine. Run it brushless - no brakes worth talking about.
I don't want much drag brake - I don't like drag brake. I want straight forward mechanical brake when I pull the brake stick back. I can dial in as much drag brake as I like but that's not what I want.
Can anyone help with suggestions of speedo and radio settings. Thanks.
johnbull is offline
