New Novak Brusless System >
Old 05-30-2006, 08:53 AM
  #1066
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by Nexus
Thanks.
I was limited by the spur/pinions I had availabe otherwise I would have run closer to 10.
Does anyone have an answer to this...
What's more important to keep an extra fan on? The ESC or the Motor? Other then the stock fan on top of the ESC what would be more valuable to keeping the temp down...
i keep the extra fan on the esc.
Marcos.J is offline
Old 05-30-2006, 10:37 AM
  #1067
treky11's Avatar
anyone running a 4.5 in their pro4? if so, what gearing spur/pinion are you running.
just got mine and figured i'd ask before i put it in. can't wait to run it.
thanks in advance for the help
treky11 is offline
Old 05-30-2006, 10:39 AM
  #1068
Super Moderator
Marcos.J's Avatar
i ran my pro 4 with the 100 spur with a 24 pinion for a 10.16 fdr
Marcos.J is offline
Old 05-30-2006, 10:48 AM
  #1069
treky11's Avatar
Thanks for the fast response!
Any issues thermaling with long runs? I plan on running a LiPo pack and hope to run longer than 5 minutes
treky11 is offline
Old 05-30-2006, 11:18 AM
  #1070
Super Moderator
Marcos.J's Avatar
not with the pro 4, I ran it with a 100/26 also for a 9.38 fdr with no thermal issues
Marcos.J is offline
Old 05-30-2006, 02:04 PM
  #1071
CarbonWorks's Avatar
Anybody have any TC rollouts for the 6.5 and 5.5.
CarbonWorks is offline
Old 05-30-2006, 02:15 PM
  #1072
we was running 8.8 overall at weekend at snetterton in uk. which is a very fast and power draining track. i running more like 7.8 and was lasting 4.5 mins then i asked about as you do and found out that running it lower didnt slow the car down at all. top end was better and acceleration was just silly. also last 5 mins peice of piss. was also lot smoother to drive. double cool can on the motor is needed as kept getting thermo cut out but hey learn from ya mistakes. also running the min drive at 3 not 2 makes it better to drive aswell.
makytc4 is offline
Old 05-30-2006, 03:03 PM
  #1073
Is that a 5.5 or a 6.5?
Old 05-30-2006, 07:25 PM
  #1074
Nexus Racing's Avatar
I ran a 9.4 at on the 4.5 at the Reedy Race. I mounted a 30mm fan facing the solder joints to keep the wires from overheating and developing resistance, and I used the Muchmore motor cooler to help keep the temps down.
Novak also used the Muchmore motor coolers some to help keep the prototype 3.5's from getting too hot shutting down.
Charlie from Novak recommends that the motor not exceed the 160 deg F range to prevent damage to the rotor.
If your motor comes off the track at 160 deg at the end of a 5 minute race, it can come off much hotter at the end of a practice if you continue run until you dump...so my best advice is to not practice longer than 5 minutes if you run an aggressive gearing setup.
Nexus Racing is offline
Old 05-31-2006, 06:48 AM
  #1075
here is my 4.5 mounted. i replaced the wirring with blue (because i'm an idiot that likes everything blue! ) and shortened the wires to the reciever with the hitec part number PN 54801S. i also braided the sensor wires (is this a good thing? or will it cause problems?) and shrink wraped the sensor wires.
hopefully i don't have heaps of resistance with my soldering. i might mount the fan over the wires if this is the case.
Attached Thumbnails New Novak Brusless System-dscf0006small.jpg   New Novak Brusless System-dscf0005small.jpg   New Novak Brusless System-dscf0004small.jpg   New Novak Brusless System-dscf0002small.jpg   New Novak Brusless System-dscf0001small.jpg
TomB is offline
Old 05-31-2006, 08:27 AM
  #1076
Trader Rating: 42 (100%+)
Nexus R..
By chance can you post a pic of your 4.5 setup.
Thanks.
Nexus
Nexus is offline
Old 05-31-2006, 11:26 AM
  #1077
Sure, here is a pic of the setup I used. I use Muchmore 30mm fans because they push LOTS of air. The fan on top of the motor is the newest version that now has a plastic clip by the bearing to hold the blades in; the "glue" mod that I posted earlier is no longer neccessary with this fan.
The heatsink has a 3mm hole tapped into it to screw the secondary fan in. I am going to rewire the secondary fan with a small plug and maybe a switch later on...I soldered it in quickly while at the Reedy.
Old 05-31-2006, 11:50 AM
  #1078
syndr0me's Avatar
Trader Rating: 32 (100%+)
What's the part numbers for those two parts again?
syndr0me is offline
Old 05-31-2006, 12:51 PM
  #1079
MR-30FAN is the # for the 30mm fan. All the fans shipped are now the newer version, same part #.
Old 05-31-2006, 12:56 PM
  #1080
Nexus Racing...Thanks for all the help.
I look forward to running the fans this weekend.
Nexus is offline
