Old 05-28-2006, 06:44 AM   #1051
AngryAsian's Avatar
Guys - can anyone give me a "lowest" ratio used for the 4.5??
For use on a large track??.. 8.86 too much??
I need to pick up some 64p gears i think...
AngryAsian is offline   Reply With Quote
Old 05-28-2006, 06:48 AM   #1052
protc3's Avatar
the best i could get without themaling is a 9.75.i kinda felt like i was overgeared.it kept pulling.the track temp was 150 degrees and i came off at 175.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-28-2006, 07:33 AM   #1053
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
9.5 is the lowest that I would go, the motor is stupid fast even when I had it geared at 10.73 it still was pulling at the end of the straight
Old 05-28-2006, 07:51 AM   #1054
AngryAsian's Avatar
Ta guys....
Will pick up some new spurs and pinions to suit... Can't wait to let it rip!
Old 05-28-2006, 08:30 AM   #1055
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Hi,
I have a new GTB with a 4.5 brushless system. After racing it twice, I quickly found that I have no brakes. So I first went into the settings of the ESC and added more brakes. Well after that, the car still didnt have more brakes. Now after putting the brake % up to the highest level, unfortunaly i dont have brakes still. I then tried adding more brakes through my radio and that didnt help. I have more brakes with drag brake than the normal braking. I NEED HELP!
Also with my ESC the setup is different. I have to turn on the ESC then hold down the set button, unlike the directions hold down set button then turn on power. The first light that comes on when i enter the setup mode, is the amber. Yet its supposed to be red.
Any help that you guys can help would be great.
Thanks,
Chris
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 05-28-2006, 11:11 AM   #1056
team green's Avatar
I'm getting a lot of heat from my fellow racer's for running a 4300 in stock. So I have to switch back to brushed. I just want to know if I have to use the fan or if I can take it off ? Like I said I only race stock. Thanks in advance...
team green is offline   Reply With Quote
Old 05-28-2006, 03:22 PM   #1057
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
I was just messing with my T2 and 4.5R using a 8.4fdr and this thing is uncontrollably fast. I drove it around up and down my street and after 4 minutes it was still relatively cool (no body). Don't try this at home!
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 05-28-2006, 05:03 PM   #1058
protc3's Avatar
just be carefull.on a race day you wont get away with that kinda ratio.after 5 or 6 thermals i was told you need to change the rotor.the motor doesnt seem to slow down when you run a higher fdr,it just seems to run more efficient and not bogg it down.even at a 9.75 it seemed over geared.10.125 on the cyclone seems to be the sweet spot.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-28-2006, 05:36 PM   #1059
Super Moderator
Marcos.J's Avatar
Originally Posted by TL_XXX-S_racer
Hi,
Thanks,
Chris
see me at superiors next weekend and Ill set it up for you!
Old 05-28-2006, 06:24 PM   #1060
Super Moderator
Marcos.J's Avatar
10.125 is the sweet spot!!
Old 05-28-2006, 08:49 PM   #1061
ok. sweet thanks Marcos. Ill see you Sunday then. Hopefully there will be a larger turn out for mod.
Chris
ProMatchRacing
Team Corally
Superior Hobbies
Old 05-28-2006, 08:55 PM   #1062
Trader Rating: 37 (100%+)
I ran the Novak 4.5 System today in my Xray T2.
The top speed and acceleration are definited on par with low wind brushed motors. My gearing was about 9.6.
Charlie/Evicerator/...
What's more important to keep an extra fan on? The ESC or the Motor? Other then the stock fan on top of the ESC what would be more valuable to keeping the temp down...
Just trying to figure out where I should mount a 2nd fan point to.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 05-28-2006, 09:02 PM   #1063
Super Moderator
Marcos.J's Avatar
Chris
I hope so too , they should be at least 5 I hope
Old 05-28-2006, 09:03 PM   #1064
Super Moderator
Marcos.J's Avatar
I keep my gearing around the 10 fdr range and my esc temp is around 160 and the motor about 165 to 170
Old 05-30-2006, 09:47 AM   #1065
Thanks.
I was limited by the spur/pinions I had availabe otherwise I would have run closer to 10.
Does anyone have an answer to this...
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
