New Novak Brusless System >
Old 04-30-2006, 08:41 PM
  #961
Super Moderator
Marcos.J's Avatar
Trader Rating: 213 (100%+)
Originally Posted by BrianH28
I see your in Tampa, do you run a speedline? I run in Port Charlotte. It's asphalt.
I run at speedline i see that you are geared at a 7.00 frd with thr rdx you need to drop a few teeth to a 20 or 21 t pinion
Marcos.J is offline
Old 04-30-2006, 08:54 PM
  #962
BrianH28's Avatar
Do you run a RDX? Did you cut your blue wire?
BrianH28 is offline
Old 04-30-2006, 09:00 PM
  #963
Super Moderator
Marcos.J's Avatar
no rdx for me , and I dont have to cut the blue wire,mine comes of the track around 161 to 164
Marcos.J is offline
Old 04-30-2006, 09:06 PM
  #964
BrianH28's Avatar
Where does the 4.5 cut off at? 180
BrianH28 is offline
Old 04-30-2006, 09:07 PM
  #965
Super Moderator
Marcos.J's Avatar
some where in there , also after your run check the temp of the esc. but like i said if you gear properlly you shouldnt have any probles with thermal shutdown
Marcos.J is offline
Old 05-01-2006, 11:11 AM
  #966
diesel's Avatar
Hi guys, I'm currently running the Novak GTB 5.5R brushless system and experiencing this problem of the car slowing down after 3 minutes +/- into play. My final drive ratio is 9.01. I am pretty sure my drive ratio is within range as some of my friends are running @ 8.85 without any thermalling problems. What could the problem be? Hope to get some answers here. Thx in advance.
diesel is offline
Old 05-01-2006, 06:28 PM
  #967
dude, if your car slows down instead of going to a halt, you have a faulty temp sensor, send it back to Novak for replacement. I contacted charlie and he asked me to send it back for replacement. So I did, and my replacement doesnt have the problem anymore.
azmio is offline
Old 05-01-2006, 08:35 PM
  #968
Nexus Racing's Avatar
Originally Posted by syndr0me
Originally Posted by bhambrent
Anyone know a online hooby shope the sale the MuchMore 30mm fan?
http://nexusracing.net/product_info....products_id=76
They're out of stock though. Same with Speedtech.
MuchMore 30mm ball bearing fan: part# MR-30FAN
30mmX7mm
Wire length=200mm.
5V, 0.17A, 0.85W
We'll have these available again later in the week. Sometimes this fan has a problem with the o-ring coming off of the shaft that holds the blades in, so it kind of "needs" a dab of med or thick CA to be applied to this area. We go ahead and perform this mod to all the 30mm fans that we ship out. It seems to push close to two times more air than the stock Novak fan...you can hear it LOL.
Nexus Racing is offline
Old 05-01-2006, 08:47 PM
  #969
diesel's Avatar
Thanx Bro, wat's the procedure to send it back?
diesel is offline
Old 05-01-2006, 11:16 PM
  #970
Michael_T's Avatar
Trader Rating: 52 (100%+)
Silly question here...
But, would it not be safer to get the 4.5 and just gear it suit your track to prevent the overgearing issue?
I've been reading up on the GTB, and it sounds like most of the issues are due to overgearing.
So having said this, would I experience any issues running the GTB in stock?
Michael_T is offline
Old 05-01-2006, 11:19 PM
  #971
viet_mafia's Avatar
I would like to know the answer to this question too as I've just recently ordered myself a GTB 4.5R system and I don't wish to encounter any of these problems.
viet_mafia is offline
Old 05-02-2006, 12:06 AM
  #972
I just ran a GTB/4.5R combo for the NSW state titles here in oz. Prolly a medium size circuit with some open, some technical bits. I ran 23mm rollout (recomended 20mm max) on IB3800's and had no probs with thermal. Approx 300mAh left after each run (almost dumped) with no thermal probs. The car was the fastest/most powerful I saw on track (kept getting compliments all day) and equal second fastest for lap speed. Ambient was approx 25degrees celcius.
If you are having probs it is most likely a faulty unit so just send it back. It seems to be you just gear till it thermals then go back one pinion tho I didn't need to in this case.
Great stuff.
Dragonfire is offline
Old 05-02-2006, 12:08 AM
  #973
viet_mafia's Avatar
what gear ratio were you running on that day?
Old 05-02-2006, 12:24 AM
  #974
syndr0me's Avatar
Trader Rating: 32 (100%+)
Seems like the 4.5R has been the dagger in the heart of modified brushed motors. I wonder if 2007 will be the year we see most of the big names in mod make the switch. If that happens, it could be a swift decline for brushed motors after that. I, for one, won't shed a tear.
syndr0me is offline
Old 05-02-2006, 12:31 AM
  #975
i think most pro drivers will give it more time for Novak and LRP to further improve the thermal and reliability problems that the ESCs have.
Try running the 4.5 in desert or tropical climates at noon time, the system tends to thermal shutdown while you're busy racing. It made many curse the system and tends to go back to brushed motors.
azmio is offline
